Hey guys,
I have a NAS from D-Link running (DNS-320 Sharecenter Pulse) and the fan on it is not particularly quiet. However, the fan can be replaced quite easily. It is a 40mm fan, 10mm thick frame. So far so good...but it runs on 5V, so I would assume the NAS does not supply more than that.
There are a bunch of 5V fans out there, so getting one is not that much of a problem. However the fan in this NAS also says it uses 0.25A, whereas most fans I have looked at use less power, some others use more. Is it important to match this value, or will a fan that requires less than 0.25A simply use less?
Could I just use a 12V fan that simply won't run at full speed because of the reduced voltage?
The PCB has a standard 3-pin fan header.
There is a picture of the fan attached to the post.
post-417-0-23073600-1384950658_thumb.jpe
https://linustechtips.com/topic/78315-40mm-fan-question/
I believe Noctuas (yeah, I know, deal with it) are under volted
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/78315-40mm-fan-question/#findComment-1074610
Another recommendation based on research: Yate Loons.
https://linustechtips.com/topic/78315-40mm-fan-question/#findComment-1074612
no need to watch the amps.
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/78315-40mm-fan-question/#findComment-1074679
So amps do not matter? That would be good news since this would at least open up options.
I could only find one 40mm fan from Noctua, it doesn't say anything about minimum Voltage on their website. I know some fans won't start under 8V-9V.
https://linustechtips.com/topic/78315-40mm-fan-question/#findComment-1074744
Okay I have ordered the Noctua fan, some guy on Amazon said need to change the pin-out on the connector but that is supposed to be no problem. I will share my experience here once the fan has arrived. Already excited to see the excellent packaging from Noctua on such a small fan, they could probably even make a metal screw look premium with their packaging :D
https://linustechtips.com/topic/78315-40mm-fan-question/#findComment-1075038
