hello
i have bought in the past a corsair h55
i have installed it yet i dont feel like its doing its work
i have an i5 4690k
msi z87 g43 gaming mobo
i've installed the h55 yet im getting huge temps just by surfing the internet
i think i have to somehow change the pump speed but im not sure how to do it?
its a 3pin cable connected to the CPU_FAN and from what i've read i cant change it through bios
https://linustechtips.com/topic/782841-help-with-h55/
120mm coolers are about the same as Hyper 212 EVO
Thats why no one recommends them.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/782841-help-with-h55/#findComment-9868246
12 minutes ago, Sakkura said:
I have an H55 keeping an overclocked R9 290 cool, so obviously this is not just how the cooler is supposed to perform.
I would suggest running the pump at full speed. Eg. by connecting it to a molex connector from the power supply, via an adapter.
ok so i need a 3pin to molex adapter
then i get the 3pin i have on CPU_FAN right now and connect it straight to the psu using the adapter
this will automatically have the pump running at full speed?
https://linustechtips.com/topic/782841-help-with-h55/#findComment-9868340
13 minutes ago, Sakkura said:
Yep, it just gets full 12V all the time.
The pump will make more noise of course, but it's not loud. You may be able to hear it at idle, when all the fans are at low speed, but once the fans spin up they'll drown it out.
ok i'll try this thnx mate
https://linustechtips.com/topic/782841-help-with-h55/#findComment-9868399
