so I bought wolfenstein and it would crash becase ig it needs up to date drivers, i go to update and it said drivers partially installed error 1603,
so i used DDU then tried again, and it did the same thing, just now my computer is picking up that I have 3 monitors when I infact only have two and becase of that all my screens are messed up because it uses the third non exist one as my main one and switching the main to either of my other two doesn't seem to fix it, when I press detect it still sees three, im guessing its becase I dont have a video driver
I just want to play my game :(
I have a 390
Smoking weed at the red light like its legal
https://linustechtips.com/topic/782449-amd-driver-help/
I have a 390
Have you tried the good old shut it off and try again?
https://linustechtips.com/topic/782449-amd-driver-help/#findComment-9864405
1 hour ago, Coaxialgamer said:
Try a slightly older driver.
i had the one before the latest and my game wouldn't work so if i did that it would be pointless unless i just give up on it, my pc works fine as in rn
https://linustechtips.com/topic/782449-amd-driver-help/#findComment-9864594
I tired to google it for older ones and i just get linked to the page with the current drivers http://support.amd.com/en-us/download/desktop?os=Windows+10+-+64
im trying to find the ones right before those
https://linustechtips.com/topic/782449-amd-driver-help/#findComment-9864796
