Looking for a solid PCI-E Wireless Networking Card
Looking for a great reliable wireless card hopefully with 5ghz. Right now I'm looking at this:
https://www.amazon.com/TP-Link-Wireless-Express-Adapter-TL-WDN4800/dp/B007GMPZ0A/ref=sr_1_1?s=electronics&ie=UTF8&qid=1495231332&sr=1-1&keywords=tp-link+wireless+networking+adapter
There are a few different versions of it. The more expensive one has "beamforming" technology...idk if that's worth worrying about. Other than that it just looks like it supports higher speeds. Not sure if any other features would be worth getting for the more expensive versions. The minimum version supports far more bandwidth than what I have.
Any other good recommendations? It would be used for gaming so yeah.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
1
The regular version is fine. But a quicker solution (if you need it) is to use powerline adapter. They are quicker than wireless. Here is one.
 https://www.amazon.com/gp/product/B00AWRUICG/ref=as_li_ss_tl?ie=UTF8&psc=1&linkCode=sl1&tag=awesomenetw07-20&linkId=8e5ad85a28af42690e611abdc1d9a82d
The way they work is they use your house power grid and send information across it. You won't have to deal with running a wire across the house and its quicker than wireless. Its also not too expensive. Bitwit did a video on this.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
I used the N900 version of that card, my mom now uses it. The only issue with the N900 version is you have to rely on Microsoft for the drivers, at least for Windows 10 as TP Link no longer supports that card directly, however the card does work fairly well.
I have heard of issues with powerline adapters in the past...but I might give it a shot.
if you have a decent wifi setup at your house and can get good 5ghz signal you shouldnt have an issue with speeds
off my 5ghz network i can pull 80Mbps and i pay for 100Mbps and i can get near 1Gbps when streaming off my NAS
power line is great but if the plugs are on separate breakers you will lose a lot of speed
Yeah. It's more about ping than speeds though.
Update: I got some Netgear powerline adapters at a local store. They were simple to setup and I got a connection to my room. So far my ping is very consistent on online games. However it's too high and consistent. I have just under 100 ping. It holds very steady but it's too much in the games I play. It's problem enough where I will probably return these and try a wireless networking card.
sorry i should have been clearer, jumping through breakers adds more latency which in turns affects speeds and ping
either way before you return them have you tried different plugs? i know its a long shot but it might improve ping if you can get the 2 adapters closer together
edit also make sure they are not plugged into power strips and plugged directly into the wall
Yeah I made sure they were not in power strips. My apartment was literally just built so I know the wiring in the apartment is not old. Currently my router isn't in its permanent location. I'm going to get it moved today. It will be closer to the inline from outside for the internet so potentially the ping will be better because the distance to the router will have to go through less cabling. Maybe that might impact my powerline performance as well. I will post an update later. I did order a wireless card (can always be returned though if the new location turns out to be better).
1 minute ago, dlink377 said:
for powerline, usually the culprit that kills powerline network is shitty electrical equipment.
in my case the culprit is cheap fluorescent tube desk lamp.
You mean on the same outlet? If so I had each on their own separate outlet.
