Recently I bought an Asus GTX 780 and along with that I bought a new power supply but when I went and and installed it I encountered a problem of my computer restarting about 1/2 hour of my GPU running stressed (no OC) this happens in both Unigen Vally and MSI afterburner as these are the only two I have tried could this be a problem that the power supply isn't delivering its full amperage on its 12v rail though. It's supposed to output 48 amps on it?
Computer:
Intel i5-2320
OEM dell XPS 8300
ASUS GTX 780
SKHynix SL 308 250GB
2x 500GB WD Blue
2x 4GB Kingston HyperX DDR3 1600MHz
2x 2GB DDR3 1333MHz
Thermaltake versa H25
3x Thermaltake Riing 120mm Red
Corsair vs600 80+ white 600watt PSU
https://linustechtips.com/topic/781469-possible-power-supply-problem/
Bro that's a terrible PSU. Return it asap and get something that can actually cope with a 780
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
I got it because it had decent rating on amazon (4.8/5 stars) and I wasn't looking to spend too much If I wasn't going to over clock but would that really be the problem that i'm experiencing
Well it could be something else but I can't really tell you that when you have such a bad PSU there. Amazon reviews doesn't tell you anything about the bad things it does, like lacking critical protection circuits or delivering unclean power that can age or kill components over time. Return it and we can help you find something that doesn't break the bank and is much better (depending on where you live)
Computer Specs:
Just to make sure I'm going to test my GPU in my friends computer (the only other component I changed) But what other power supply would you recommend? Preferably something under $50 because you see 750 watt 80+ bronze semi-modular Evga power supplies at that point after MIR
In the US?
If that's the EVGA 750W B2 you're talking about, and I suspect it is, get that. Don't get the BQ unless you can't find anything else.
You can drive a 780 on a good 500-500W though. So look for Seasonic S12II 520W or you could do an EVGA 600B if you find it. Not the most amazing PSU but better for sure. Out of those two the Seasonic gets the edge
Computer Specs:
14 minutes ago, Energycore said:
In the US?
https://pcpartpicker.com/product/fZyFf7/seasonic-power-supply-s12ii520bronze
https://pcpartpicker.com/product/nB3RsY/seasonic-power-supply-s12ii620bronze
https://pcpartpicker.com/product/V9bp99/evga-power-supply-100b10600kr
https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na
which one of these would you say is better as they are all near the same price point?
Computer Specs:
I found the reason the fan of the power supply never turned on so when I ran the benchmarks the PSU would overheat and turn off
Oh gotcha, that's a factory defect, but you should still change it
Computer Specs:
That PSU has Over/Under voltage/current protection so it'll protect itself and your components once it detects something that's out of spec so I wouldn't really worry about it damaging other parts of your system.
If the fan is not running at all, then I would suggest that you get it replaced from Amazon OR you can always get a replacement from us via RMA process. That PSU is defective.
I hope you don't mind me bashing the VS series though :P
I will concede that you guys did a great job with the new CXM
Computer Specs:
Not at all, its all good :) At this point, we all know by now where the VS sits in our PSU hierarchy. I just want to make sure that we all deliver the correct message, that's all.
But yeah, I have to agree, the latest iteration of CXM series has been solid thus far. Our PSU team has done a great job of implementing the new spec.
10 hours ago, BrokenProgram01 said:
would the 520watt one work if I decide to over clock because that just dropped in price to $24 after rebate
Yeah you'll be pushing its max power so it might get loud, but the S12II 520W will work on an OC 780 and Sandy i5
Computer Specs:
I'm looking forward to what you guys have next for the PSU :D
Computer Specs:
Maybe next time you revise it go something thats not CWT?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
As long as they collaboration of the two company produce something good as display with the HXi/HX/RMi/RMx in the high-end segment and the new CXM in the budget segment, while I do like to see what they can do with other OEMs, I don't mind Corsair continue using them.
