i need help powering my gpu
Solved by richardwei6,
1 minute ago, dylants said:I just bought an asus strix rog 1080 ti. When I plugged it into my pc, it didn't power on. My pc works without it, but not with it. It has indicators that show if it is powered or not, and they were green. Despite them being green, I think that it is the power that is making it not work. I connected 2 8 pin connectors to it, but they both said cpu on them. Is that the correct 8 pin for it? Also, do I have the right connectors for it on my power supply? I have a corsair hx1000i.
CPU? Not a cpu, Its supposed to be PCI
