Right now I have a g403 wireless and I like it, but I'm a bit of a stickler when it comes to peripherals, and was wondering if there are any mice out there better than the g403 for less than 100 USD.   I'm not looking for an entire keyboard on the side of my mouse either, 2 or 3 extra buttons on it maximum.
https://linustechtips.com/topic/780103-best-wireless-mouse/
the only wireless mice I can recommend for under a hundred are the logitech g602 and MX master. they are not really a significant upgrade at all from the 403. infact i prefer the 403 to the 602.
if you really want an upgrade spend a bit extra and get something like the g900 chaos spectrum.
scratch that: i cant recommend the logitech g602. its sensor is just such a downgrade from the 403.
Edited by coldhelios
PC: ryzen r7 1700 | Gigabyte GTX 1080 Windforce OC | gskill 16gb ddr4 2666mhz | Asrock AB 350m pro4 mobo | 120gb m.2 ssd, 240gb sata ssd, 2tb 7200rpm hdd | 750W Coolermaster powersupply | Phanteks Eclipse case | monitor: BenQ PD2500Q
https://linustechtips.com/topic/780103-best-wireless-mouse/#findComment-9835701
22 hours ago, Aytex said:
403 and g900 are the same but different shell shape, 602 is inferior to both
So. Just get the 403
You get more features on the G900, such as side buttons on either side that you can take off. A tilt and infinite scroll wheel. 2 DPI buttons instead of 1. Ambidextrous if you're left handed
On the other hand the G403 has more of a ergo shape that many people prefer, and if you don't want the extra features then this can definitely swing it.
As far as the wireless tech and sensors are concerned they are the same implementation in both mice
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
https://linustechtips.com/topic/780103-best-wireless-mouse/#findComment-9840835
G900
I don't even use it for gaming. It's just nice to finally have a decent mouse with thumb buttons for left hand and not accidentally hit right hand thumb buttons.
Tilt wheel, Logitech always has had a wheel that works right for me, weight, resistance, click.
Ryzen 7 2700x | MSI B450 Tomahawk | GTX 780 Windforce | 16GB 3200
Dell 3007WFP | 2xDell 2001FP | Logitech G710 | Logitech G710 | Team Wolf Void Ray | Strafe RGB MX Silent
iPhone 8 Plus ZTE Axon 7 | iPad Air 2 | Nvidia Shield Tablet 32gig LTE | Lenovo W700DS
https://linustechtips.com/topic/780103-best-wireless-mouse/#findComment-9841447
