I have an Intel 600P and it is slow sometimes, a sequential read test shows dips into the 200 MB/s range (something my old Samsung EVO840 used to do).
Compare this to my Samsung 960 EVO:
Anyone know why the Intel 600P would dip so low? On My 840 EVO defragmenting actually fixed the issue (later a firmware update from Samsung). Would defragmenting the Intel 600P fix it?
https://linustechtips.com/topic/779827-intel-600p-dips-in-speed/
1 minute ago, nerdslayer1 said:
do a real life test
I can test the thermals without software and it says the same as what the software reads. It's not from temperature throttling. It's currently in my Ryzen system but if I put the drive in an Intel rig it also has dips in sequential speeds there as well.
https://linustechtips.com/topic/779827-intel-600p-dips-in-speed/#findComment-9832428
nope speed test using a 5 to 10 gb file
https://linustechtips.com/topic/779827-intel-600p-dips-in-speed/#findComment-9832434
this is a common complaint with the Intel 600P - something to do with the SLC cache/buffer when working with large files.
You don't "defrag" SSD's / solid drives - thats only for hard disks.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/779827-intel-600p-dips-in-speed/#findComment-9834204
