8 hours ago, Fleanuts said:
Clean install did not work, i already have updated chipset from AMD.
Completely clean windows install didn't work? Damn I'd have bet money that was it. Tbh 750W is plenty so unless your PSU is failing and about to die I don't think that's the issue.
You have double checked there is no additional CPU power socket on your motherboard? Mine for example has 2.
Failing that I'm going to say poor delivery from motherboard and replace the motherboard.
on this particular board there is a pin connector in the top left next to where i have my cpu power socket but i have no connector for it. I assumed it was meant for a different PSU
  • 1 month later...
Buddy, I have EXACTLY the same struggle! Did the additional juice from the 8pin connector help to maintain the OC?
Step one reset coms
step 2 load optimized defaults
step 3 flash latest bios
step 4 load optimized defaults again and boot into windows
step 5 shut down
step 6 go to bios and follow @tom_w141s guide
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
