Need a quality keyboard and mouse
Red Saum
I'm not interested in a "gaming" keyboard or mouse. I just want something that will suit me, is of good build quality, and feels nice when it's used. Budget of $100 or so.
Thanks.
edit: I don't play any games either.
Each?
K70 is good. Doesn't matter if it's aimed for gamers or not, good build quality and MX switches. Don't go for Romer G if you type a lot; I have a G910 and I hate Romer G (don't game much)
a good mouse would be MX Master/G502.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
1 minute ago, PCNoobie said:
Do you play FPS, or MMORPG?
I don't play video games.
K70+ MX masters is a good combo for productivity.
MX Master! I'm using mine right now. Super comfortable, tons of programmable buttons (I've got it set up to save, undo, cut, copy, and paste in Excel), and it's got a side scroller wheel, handy for big spreadsheets, video editing, or weirdly formatted 90's websites that scale incorrectly.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
You know Thise already has hot Keys?
Yup, though I use a MacBook Pro, iPad Pro, a Windows PC with a Chinese knock-off (Though the switches are about the same as Cherry MX Blues) keyboard, an iMac, and various other laptops and such, depending on what I'm doing or who I'm helping out. All the switching keyboards don't help with doing shortcuts, and I have to look down from my monitor at my hands/keyboard (It's actually quite hard on your eyes when you do it all day) to see the keys. And the whole time, my hand is still on the mouse. It's really just a small efficiency boost that's massively helpful over a day of work.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
That explains it ;)
