PC won't post.
ZetaByte
Hi all. I helped a friend of mine build their computer starting a few months ago. She's been having a lot of problems with her graphics card. Whats happening is, everything else turns on when she powers the pc on but the graphics card. All the fans spin up (including CPU) and everything else receives power. But for some reason, the fans on the graphics card don't spin and there is no display being outputted from the graphics card. I'd really have to have an answer or two ASAP. Thanks!
Oh, sorry.
Specs are:
FX 6300
Cooler Master T2 CPU cooler
MSI 970A-G43 Plus
Corsair Vengeance 8gb 1600 DDR3
Seagate Barracuda 2TB drive
RX 580 8GB armor
Corsair CX 750 psu
Any other info I should provide?
Need a little more information please.  What make/model is the GPU?  What make/model is the mobo?  Is the GPU properly seated in the pci/pcie slot?  Is the power cord properly seated in the GPU?  What have you done to troubleshoot the problem?  That sort of information helps in trying to find a cause.
Have you installed your GPU (AMD/NVIDIA)drivers or put the PCIe 4pin/6pin/8pin power into the GPU. This comment is if the computer is custom built or you have placed a GPU in a old computer.
She has reseated the card three or four times at this point, even tried to change slots to maybe see if it was a dead pci-e slot. Power has been reseated all those times as well just to make sure. Even reseated all cables on the PSU itself. I've tried having her reseat ram aswell.
This is a brand new, custom pc. We haven't even been able to get it to post.
I don't know then? Has the GPU got a PCIe power connector connected depends on GPU it could be a 4pin/3pin/8pin or 2 of each. The power connector is  usually yellow and black depending on PSU though.
2 hours ago, ZetaByte said:
Oh, sorry.
Specs are:
FX 6300
MSI 970A-G43 Plus
RX 580 8GB armor
Corsair CX 750 psu
If I'm not mistaken the RX 580 Armor requires an 8 pin and a 6 pin power connector.  Don't quote me as I'm not able to look that up at the moment.
Also when you do get it to post remember that the 580 has a fan silence setting.  It means the fans will not spin till it reaches a certain temperature.  Then they start to spin upon hitting it.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
