2 minutes ago, JDE said:
But I would strongly recommend the 1700 over 1800X
no 1800x is better then people think .I KNOW YOU CAN GET SAME PERFORMANCE for less price but power consuption difference is also great which will cause me to have a buy a better psu if i overclock so i better buy 1800x over 1700
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824170
wha?
1800x is 95W
1700 is 65W
OC doesn't really increase usage much.
It will be the same,
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824173
6 minutes ago, sarggames said:
Why 6 core(i dont understand how they come into our talk) 1800x is 8 core
As far as I can tell, you're only going to be gaming. Though 1700 is a much better price/perf part than 1800x if you really want 8 cores.
Almost breaking sig rules 1.0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824177
Sarg, please state exactly what you want to do with your processor. You're just throwing around speculations otherwise.
As for your TDP argument:  At idle, 1700 overclocked to 4.05 GHz draws 66W, whereas the 1800X at base clocks pulls 71W.
Under load, 1700 overclocked pulls 236W, a mere 16W draw over the 220W of the base clock 1800X.
Source: https://www.bit-tech.net/hardware/2017/03/08/amd-ryzen-7-1700-review/6
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824181
Just now, sarggames said:
pls i told you me poor so can take risk
can or can't
but this isn't risk. If OC gets it unstable, reset CMOS and start OC again.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824183
As for your TDP argument: 1700 overclocked to 4.05 GHz draws 66W, whereas the 1800X at base clocks pulls 71W.
So i misread but any way i am not overclocking as no money for cooler.I want to play games when they start using multiple threads which is the argumen for ryzen over i7 .IN Those games which will be better
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824193
3 minutes ago, sarggames said:
I want to play games when they start using multiple threads better( the argumen for ryzen over i7).IN Those games which will be better
Like the other guy said, they won't use too many cores for a while. Taking that into consideration, if they're close enough in price where you live, might as well go for the better performing one, which would be the i7.
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824211
Just now, LyondellBasell said:
Gaming is not going to outpace even a quad-core in the next decade, regardless of any and all multi-core optimisation. Your budget is best spent on the fastest VGA card you can possibly afford.
I HAVE TO BUY A CPU ALSO .i DONT HAVE GOOD COMPUTER And since people are buying ryzen more game developers will surely optimize games for ryzen .They will run better on more cores or something like that.If i buy a cheap cpu then i will have less money to buy a good gpu and i already have 2 r9 380x so it will not be worth it
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824212
Insane troll logic aside, if your computer isn't very good then it might not be able to handle either CPU. What are your specs?
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824217
i DONT upgrade fast so i have to buy carefully once after sometime this thing will happen and i want better performance at that time
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824218
Here's what you need to do: forget everything you just posted. Buy a 6700k. Start saving for a Volta card when they become affordable next year.
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824224
Here's what you need to do: forget everything you just posted. Buy a 6700k. Start saving for a Volta card when the become affordable next year.
dude i dont earn much this is my scholarship money .i WILL NOT BE ABLE TO BUY VOLTA CARD I JUST have to choose between them .
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824232
Then don't buy Volta. Buy secondhand Pascal. People will be letting their 1070s go like hotcakes come June 2018.
https://linustechtips.com/topic/779046-urgent-help/page/2/#findComment-9824234
