No. The distinction between single-threaded and multi-threaded is that a multi-threaded command can be spread to other cores while a single-threaded command cannot. BF1 is a good example of many single-threaded commands/calculations with the ability to use many cores, i.e. using multiple cores =/= multi-threaded...ness(Going to need Webster for the right word on this one).
Edit: BF1 also has quite a few multi-threaded calculations such as building destruction physics where the effect doesn't have to be the most accurate and thus latency isn't a huge issue.
That said, IPC and frequency are both as integral to performance [as core count]. When a program uses mostly single-threaded commands but can take advantage of multiple cores effectively is when you will get a truly worthwhile engine. This is why I don't usually jump to the conclusion that "more cores are better" as this doesn't take into account the characteristics of the individual program in question. If you were to ask me if hyper-threading is useful for Autodesk/Solidworks, I would say no if you're getting a slow CPU with said hyper-threading unless your specific use case is rendering models which takes advantage of the hyper-threading's scheduling habits.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
