I recently lost my job, and could not build my computer, as I had planned before (I have many posts on this subject, simply to get more out of the system). that being said, I recently also got a new job! that pays more! and I would like to build a computer similar to this
https://pcpartpicker.com/list/RZ4T7h
this is the build, it may show up as canadian, I dont know why, pcpartpicker thinks im from up north. im not. go to usa for pricing.
im just curious about the build, and i am waffling between a 1080 and a 1080 ti. im going with 3440x1440 monitor, and want decent refresh rates.
thank you for looking, and thanks for any help!
https://linustechtips.com/topic/778130-my-build-again/
was going to ask why skylake, but saw you purchased it. 1080Ti would be my best bet if you want max performance, but if you wan to stay lower in cost than a 1080.
Delta R5 Build
CPU: AMD RYZEN 1600 Purchased
Motherboard: ASUS PRIME B350-PLUS  Purchased
RAM: Corsair Vengeance 16GB DDR4 3000MHX (2X8GB) Purchased
CPU COOLER: DeepCool GAMMAXX 400 GT RGB Purchased
GPU: Gigabyte Xtreme Aorus 6gb GTX 1060 Purchased
Case: NZXT S340 (White) Purchased
PSU: EVGA 550B3 Purchased
HDD: WD Blue 1TB  Purchased
SSD: Sandisk SSD PLUS 120GB Purchased
Wifi Card: Asus PCE-N15 PCI-E 1X Purchased
--BUILD READY--
https://linustechtips.com/topic/778130-my-build-again/#findComment-9813996
You could save a bit of money and get the vengence rgb ram and stick with the 1080ti if in your budget. Also maybe think of picking up a hdd for more storage. Good build overall. Also congrats on the new job :)
Edit: I see a lot of people pointing out the powersupply. Evga G2 is a good line to look into.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814001
What is the purpose of this build? Just gaming?
Although it varies from game to game, at 3440x1440 100Hz you typically want all the GPU power you can get. So I suggest you stick with the GTX 1080Ti.
I'd also change the power supply since EVGA's NEX/G1 series is mediocre at best. Grab the EVGA SuperNOVA 550 G3 for a bit more.
I'd also grab a HDD if you don't already have one since having one for mass storage would be ideal.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814002
im hopeing to stay above 60 fps at all times, and have some games like doom and other highly graphics optimized games to run closer to 100, and saw that doom tends to run at 100 fps on the 1080 at 16:9 1440, so im assuming the ti will do the same at 21:9
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814003
NOT THE NEX
NOOOOOOOOOOOOOOOO
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814008
Get a Noctua CPU cooler.
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814042
the gskill looks nicer imo, and is asus aura compatable, as well as the case, which i like.
for the most part, yes, gaming, and the power supply is something i will look into, but i have to ask, what is bad about the power supply? also, the hdd will be bought once i run out of storage. 240 is plenty for the time being
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814049
The NEX series have terrible voltage regulation, which can potentially damage the VRMs of your GPU and motherboard.
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814054
The NEX is tier 4 on our tier list while for the same price you can get a Tier 2 semi-modular or a Tier 3 full-modular unit.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814068
haven't seen the tier list yet, thanks
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814079
Some changes.
PCPartPicker part list: https://pcpartpicker.com/list/Xtpsf8
Price breakdown by merchant: https://pcpartpicker.com/list/Xtpsf8/by_merchant/
CPU: Intel - Core i7-6700K 4.0GHz Quad-Core Processor  (Purchased For $0.00)
CPU Cooler: be quiet! - Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($65.49 @ SuperBiiz)
Motherboard: Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard  ($186.99 @ SuperBiiz)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($159.89 @ OutletPC)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($84.99 @ Jet)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.89 @ NCIX US)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card  ($744.99 @ SuperBiiz)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($89.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.49 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($30.00)
Case Fan: Corsair - Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM  120mm Fans  ($27.88 @ OutletPC)
Monitor: Asus - ROG SWIFT PG348Q 34.0" 3440x1440 100Hz Monitor  ($1199.90 @ Amazon)
Total: $2717.49
Generated by PCPartPicker 2017-05-10 23:49 EDT-0400
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814087
Just now, xzantian said:
https://pcpartpicker.com/list/39G4kT
current parts list (there are to 1080ti's just to see if i could eventually move to sli if it gets better in the future)
If you are upgrading, I don't think SLI is worth it. Volta, Vega and Navi will be much more powerful.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814090
Yes, SLI is just complicated now
My head on 2019 :
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814092
1 minute ago, JDE said:
Some changes.
Total: $2717.49
is there a reason for the move away from the 850 evo? i have heard many good things about it, and would like to keep it as my m.2 boot drive, but if there is a good reason to move i will. the hdd is one of the two i was looking at, the other being the wd black, for reliability, but i dont think i will go that direction. as for the cpu cooler, ive had the dark rock 3 suggested to me, but i have also seen some pretty good benchmarks for the corsair aio, and have never done liquid cooling before, so it would be a first.
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814099
I'm pretty sure the 850 EVO is a AHCI M.2. SSD. This means it will run at SATA speeds. The SL308 is a very good alternative. Also NVME is useless at this point. For the HDD, you should consider this one and the Seagate Barracuda. Both are reliable. I have both. I like air cooling, but if you like liquid cooling, you can change it.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814106
ok, thanks everyone for your imput, im going to be changing out quite a few parts, and will be posting a completed build some time in the next month or so once i get paychecks!
also, hit solved while trying to thumb up... stupid laptop. would have had to mark it solved anyway.
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814113
You can "un solve"
anyways that post probably won't be the final answer, so can you unsolve it?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814119
do you think their are any other changes you would make?
Well you like RGB so perhaps RGB fans with controller?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814126
probably not, the case rgb and the ram seem fine, i think i may put a strip inside the case if anything. the case has all the fans i need for now, and rgb fans would be a future upgrade
RGB fans build muhahahaahaha
PCPartPicker part list: https://pcpartpicker.com/list/rBjxm8
Price breakdown by merchant: https://pcpartpicker.com/list/rBjxm8/by_merchant/
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($96.99 @ Best Buy)
Case Fan: NZXT - Aer RGB140 (3-pack) 71.6 CFM  140mm Fans  ($86.99 @ SuperBiiz)
Other: NZXT Hue+ RGB Colour Changing Internal LED Controller  ($59.99 @ B&H)
Total: $2868.09
Generated by PCPartPicker 2017-05-11 00:05 EDT-0400
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/778130-my-build-again/#findComment-9814135
