I got my PC about 3 years ago and when i added a second hard drive i started having problems with my drives where 1 keeps disconnecting so i went back down to 1 and that seemed to fix it for awhile until i started getting a BSOD every couple weeks and then after a few months of that on boot up i get an error that says "Hard Disk Failure is imminent" and i cant sign into anymore windows so i went and bought a new one another 1TB WD HDD and ive had this one for about a month until the same thing happened and i have tried new sata cables , different sata ports, and different HDDs.
Please and Thank you for any help
My PC specs:
6 GB ram
windows 7 64/bit
(thats all i know if you need more tell me and ill try to figure out how to find it out)
https://linustechtips.com/topic/778066-hdds-keep-dying/
https://linustechtips.com/topic/778066-hdds-keep-dying/#findComment-9813239
5 minutes ago, Windows7ge said:
I'm thinking either motherboard or bad PSU. Drives shouldn't die like that.
+1 on bad psu.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/778066-hdds-keep-dying/#findComment-9813253
38 minutes ago, Roberito said:
how would i check to see if thats the problem and if so how would i fix it?
Well you'd install a new PSU and run the system for some time to see if the issues stop.
https://linustechtips.com/topic/778066-hdds-keep-dying/#findComment-9813496
25 minutes ago, Roberito said:
is there a way to find out that doesnt involve spending $ until after i know the problem because im kinda tight on $ rn
Steal a power supply from another computer.
https://linustechtips.com/topic/778066-hdds-keep-dying/#findComment-9813585
20 minutes ago, Roberito said:
well is the HDD actually dead or should putting in a new PSU fix that problem?
Hdd is most likely dead.
Best bet would be a new PSU.
https://linustechtips.com/topic/778066-hdds-keep-dying/#findComment-9813766
I can't say weather it is or not I can't physically inspect it. According to your story though these drives are dying quickly one after another. This isn't normal. Something is causing them to die prematurely. It's most likely the PSU. If it's a crappy brand or simply malfunctioning it could decrease the lifespan of the other hardware.
https://linustechtips.com/topic/778066-hdds-keep-dying/#findComment-9813769
