Try using an older driver. Make sure to use DDU to uninstall the driver.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806400
4 minutes ago, Wimpy_Cobra said:
how would you do that?
Do what? Also, make sure you quote the person you're responding to they get a notification.
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806413
Ill just reinstall the Driver from my disc
Don't do that. Get the driver from AMD's site. Guru3d also has a good database of older drivers because I know AMD's site is a bit hard to use to find older ones.
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806449
Also, DDU is display driver uninstaller. Just do a google search.
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806456
7 minutes ago, Wimpy_Cobra said:
I'm not sure which driver to downgrade to. I'm nervous that ill install adware from a non amd website.
There's no adware on guru3d. Try 17.4.2. That's what I'm using.
http://www.guru3d.com/files-details/amd-radeon-software-crimson-relive-17-4-2-driver-download.html
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806564
3 minutes ago, Wimpy_Cobra said:
AMD crimson relive?
Yes.
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806574
try shutting down pc, then unplug monitor wait then plug in and turn on monitor before turning on pc
just a suggestion
believe this is an issue with windows and displayport being treated as plug and play device I have ran into this issue many times
on my pc and few people I know I cant manually turn off my monitors while windows is running and must have monitors on before I turn my pc
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806673
just a suggestion
would this be related to why my PB287Q sometimes turns on in DP 1.1 mode ? Every now and then when i turn my PC on it boots to a sickening 3840x2160@30hz instead of 60hz, and i have to power cycle the monitor to fix it
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806693
possibly
I have searched high and low for a real fix
it also will fuck with my resolution and monitor layout
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9806713
Make sure the monitor is running in DP 1.2 mode, check in OSD settings of the monitor.
Try different DP, different cable, different drivers
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9807041
1 hour ago, Wimpy_Cobra said:
my cable is new and works fine
Did you use the Cable that was included with teh Monitor, or did you buy a new Cable?
if so, which Cable did you buy? Maybe you bought a bad one.
There is a chance, the included DP Cable isn't that great, and has too low quality for 144 Hz.
There are tons of people with a 4k / 60 Hz monitor, where the included DP Cable was NOT able to transfer 4k @ 60 Hz.
https://linustechtips.com/topic/777510-144hz-wont-work/#findComment-9807098
  • 2 weeks later...
