Please help I'm an idiot
Solved by TheRandomness,
Just now, Drill said:Also jayz is the one who told me to do this so.. windows does not recommend a safe mode, the screen just freezes
Shut the PC off halfway through a boot. It should go into the recovery assistance centre, where you select alternative boot methods or whatever, and go into safe mode from there. Then uninstall afterburner.
