Upgrade Advice
Solved by Jake3231,
30 minutes ago, dizmo said:Yeah that's what I'd go for. That or an SU800. I think you get a little more out of the Crucial though. 512GB vs 525GB.
Thanks! My only question after that is backup. I think I'll get the MX300, but what if I have a few hundred GB out of the 1TB that I want to keep? I have a 4TB USB 3 backup hard drive. Would it take long to copy about 130GB of data over a USB 3.0 connection?
