What's happening to my Sapphire 7950 dual x? Audio snippet below.
I get this weird kind of buzzing noise. I don't think it's coil whine. It mostly happens ingame (weirdly enough not always when manually adjusting the fans). It happens mostly between 45-55%. I purchased the card a couple months back and it has gotten worse (slightly).
Snippet: http://vocaroo.com/i/s0PVIpgOVXWB
It's the hnngggg sound that sounds like it's grinding on something.
Can I fix this myself, is it normal or should I take it back?
𝙶𝚊𝚖𝚎𝚜 𝚊𝚛𝚎 𝚙𝚛𝚎𝚝𝚝𝚢 𝚌𝚘𝚘𝚕
https://linustechtips.com/topic/77662-buzzinggrinding-sound-7950/
I am not sure if it's coil whine, but I'd RMA it.
how hard are your fans spinning?
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
Are there any wires that may get caught in the fan?
@Anubikai gave me an idea - are the screws holding the card in screwed in tightly?
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
its not normal. Maybe its the vibrations of the fans? when my two corsair fans are ramped up on my h80i they make a similar sound but i only hear it when the case door is off and my cpu is hot. I dont have a rubber vibration isolating mounts....im using stock h80i fans........other than that my pc is silent =)
-Anubikai
| i5-4670k at stock until I do a custom WC loop | H80i | Asus Matrix Platinum 7970 at stock until I do a custom WC loop  | MSI Z87 GD65 | 1TB CAVIAR BLACK | 250gb Blue Scorpio | HX750 80 PLUS GOLD modular | 16GB INTEL EXTREME EDITION PATRIOT 1866MHZ | Coolermaster Storm Enforcer with two Red 20cm fans intake and exhaust |
There are some bugs in it and they're getting chopped up.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
54% in the clip.
No wires anywhere. Only a network card a couple PCIe slots down. Should I try to tighten or to loosen the screws? I'll go check them now.
-Anubikai
I'm using the define R4 so everything is pretty muted already but the way the sound forms is just really, really annoying. It's this grindy pitchy noise.
Every AMD card I've owned has had some kind of coil whine from barely noticeable to "oh my god my ears, why?!!".
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
    Asus Maximus VIII Hero
  • RAM
    16 Gig of G.Skill TridentZ Series 3000 Mhz
  • GPU
    EVGA 1070 FTW edition
  • Case
    Fractal Design Define R5
  • Storage
    Samsung 850 Series 250GB for boot + WD 2TB Black
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
For the record: the GPU fan was indeed defective and the noise wasn't normal. Just took it back to the shop and I got credit for it under the standard 2 year warranty (EU). Got a Sapphire r9 280X Vapor-X  for €14 extra  :D
Lucky duck.
My daily driver.
  • CPU
    Intel i5 6600 K
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
    Corsair RM 750W
  • Cooling
    Corsair H100 V2
  • Keyboard
    Corsair K 70 LUX
  • Mouse
    Corsair Raptor M45
  • PCPartPicker URL
