I  want to upgrade from my xps 15 9950 to a gaming computer that can run games at a higher fps and quality. I have no idea what im doing but I put together a pc on pcpartpicker that is a bit past my price limit. I  need a monitor with this setup for around 1600-1900 dollars also. I want a good monitor with this computer that is above 100 hz. heres the list
https://pcpartpicker.com/list/g8Dnqk
https://linustechtips.com/topic/776596-first-pc-build/
an overclocked 1700 would be better than 7700k
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795075
i would get rid of the 1080ti especally if your only playing at 1080p.  a 1060 or 1070 would more then suit your purposes
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795081
he wants to be playing games at 144hz though, and if you look at AAA titles at top setting its actually not as unreasonable as you might think to go for the 1080ti
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795084
5 minutes ago, Zyndo said:
no it would not. not for a high refresh rate gaming rig. there is nothing better than a 7700k in a high refresh rate gaming rig.
the fps difference is very little, especially if it's at 1440p 144hz, the 1700 will let you do more things faster with the PC as well, as the OP might be doing something else than just gaming. Something that is heavily multi thread lets say.
I suggest this
https://uk.pcpartpicker.com/list/vb7MxY
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795106
1 minute ago, AceJughead said:
Ill be using this for gaming and 3d modeling
you definitely need a 1700 then as 3D modeling requires/loves more cores.
I suggest this list https://uk.pcpartpicker.com/list/vb7MxY
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795117
Just now, VinZie said:
Convert it to USD. It could be a different price.
whoops I thought it was a GBP, right two seconds.
it's $100 over, https://pcpartpicker.com/list/vb7MxY I will see if I can get it under without hurting performance too much
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795136
is there a quick way to switch to US dollars
yep, I have done it already sorry. (it's in the top right of the page though, and you just change it to the said country though)
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795144
there isn't much I would change on this build if you're willing to fork out the money for something like this. pretty solid machine. Maybe would swap the seasonic unit for an evga 550w G2... about the same price, but what you lose in wattage (wattage you won't be using) you gain in quality.
https://pcpartpicker.com/product/qYTrxr/evga-power-supply-220g20550y1
there are some areas you could trim some cost out of if that was your desire (such as the motherboard, the storage options, and so on) but if price isn't an issue you could buy as is. You may also wish to buy a better CPU cooler if your desire is to reach really high overclocks on the CPU. nothing wrong with the H7, and its really good for what its price is, but it doesn't have the raw cooling performance of some of the more high end coolers on the market.
10 minutes ago, AceJughead said:
Would i need a sli motherboard, does it matter?
if you're getting a 7700k with the intention of overclocking, then you will need a Z series motherboard (Z270 for kabylake, although you COULD also get a Z170 motherboard provided it has kaby lake supported BIOS). all Z series motherboards are SLI compliant, so basically what I'm saying is you're going to get a SLI enabled board whether you like it or not (assuming the board physically has the slots for it)
the OP has specified that this is a gaming computer and his desire is to have extreme gaming quality so making an argument about ryzen being better at other things at the cost of some gaming performance doesn't make any sense at all. as far as "the fps difference is very little".... the difference can easily be 30% or more in CPU bound titles and CPU bottlenecked situations (with the exception of the occasional game like BF1 which is capable of utlilizing the additional cores/threads which comes with the Ryzen chips).
So there is absolutely no good reason to avoid intel and go ryzen for this user. You aren't exactly wrong that the 1700 is more versatile, but this user doesn't want versitility... he wants as much gaming performance as his money can buy, and no matter which way you slice it, that is the 7700k. Period.
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795146
Just now, Zyndo said:
the OP has specified that this is a gaming computer and his desire is to have extreme gaming quality. as far as "the fps difference is very little".... the difference can easily be 30% or more in CPU bound titles and CPU bottlenecked situations (with the exception of the occasional game like BF1 which is capable of utlilizing the additional cores/threads which comes with the Ryzen chips).
The OP then later on said that they do 3D modeling with will love the 1700. so ryzen is a good idea in this case.
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795157
thanks, why would i need 2 monitors
why not? you can just get one if you want (I have two and love it, as the second one I use for browsing the web, and other one can have your important stuff on it. Also can you quote me if next time if it's aimed at your response so I can get a notification to tell me to respond etc.
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795170
I just now learned i could do this, thanks for the help. This will probably be my final build. https://pcpartpicker.com/list/ZGKnqk
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795193
good choice :P
yea if your doing CAD the 1700 will help drastically
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795210
Very well, didn't see that (even though I did check several times R.I.P. me lol). You could still make an argument for the 7700k. it would depend on his exact workload. its not like a 7700k is garbage at 3d modeling/rendering or anything (although an 8 core R7 is definitely better at it, no doubt) buuut you're probably right about him wanting to go R7.
@AceJughead if you're having any confusion about R7 vs. i7, allow me to clear it up for you. your Ryzen CPU will be much better for your modeling/rendering uses, and the 7700k better for reaching 144hz as often as possible in your games. when it comes to gaming, even at 1080p, even with a 1080ti, your will still often hit your GPU bottleneck before you could hit a Ryzen CPU bottleneck, in most games, if you are running above ultra settings or have tons of AA turned on. so having a 7700k will not, in all cases, give you 30%+ more fps. with how gaming workloads work it basically equates to "potentially" 30% more fps (depending on games and settings).
so in short the 7700k will not ALWAYS be better than an R7 chip even in gaming. Basically when it comes to gaming, the 7700k is "king" and R7 is "good enough". when it comes to your 3D applications the R7 is "king" and the 7700k is "good enough". its up to you which you value more.
If you're the kind of guy who doesn't mind turning down the occasional graphical setting here and there (something less important like shadows, antisotropic filtering, or whatever setting you feel you can live without in some games) in order to boost framerates to get 144hz as often as possible... then I would recommend the 7700k in a heartbeat as it will get you there more often than an R7 will. If you're the kind of guy who wants maximum possible graphical quality, my recommendation would be the R7 because you will often be bottlenecked by your GPU before the R7 runs out of performance, so having a 7700k wouldn't yield additional fps anyway.
You don't NEED two monitors. Its a preference thing. Lots of guys prefer multiple monitors because it gives them more screen real estate (more space to manage what they're doing) or an easier way to multitask, or it simply makes them feel like a badass when they sit down at their rig. I'm the kind of guy who has never found much use for 2+ monitors, and therefore wouldn't waste money on additional screens. I stick to the one, or use the money I would have invested in two or more monitors in order to purchase the best monitor I can afford. for gaming, having 3 monitors spaced horizontally can give a great experience in the right games (such as, but not limited to, flight simulators or racing games) but if those aren't your scene then I would recommend investing in the single best monitor you can afford.
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795286
2 minutes ago, Zyndo said:
-SNIP-
the 8 core R7 is much much better at the CAD the 7700K is good at CAD but the 1700 is much better and probably worth it, Especially if the OP is rendering shit as the 1700 is maybe 2 times faster roughly at rendering (that's very rush, just because it's got twice the threads, which makes a massive difference)
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795322
that would assume the given application can scale 100% with additional cores/threads (which they very rarely do). you then also have to consider the lower IPC and clockspeeds of the R7. don't get me wrong, the R7 is DEFINITELY better at it... but you're probably looking more in the neighborhood of 50-60% faster on average, rather than a straight doubling. and i'm not saying he SHOULD go for a 7700k anyway, i'm just saying there is an argument for it depending on his needs and desires. don't need him spending thousands on a rig he will be upset with because he does 90% gaming and 10% modeling/rendering and then went with an R7 anyway. just trying to give him all the facts.
https://linustechtips.com/topic/776596-first-pc-build/#findComment-9795365
