Q1: Would I be able to maintain a steady 250 FPS with this build? (If NOT which parts should I upgrade specifically?) (If YES which parts could I downgrade to save money?)
Q2 : Is this build even good? Q3 : Does anyone have recommendations for a surge protector that could support this computer and monitor plugged into it (What I'm planning to use is the APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector)
https://pcpartpicker.com/user/2g3k/saved/#view=HtkZLk
Overwatch in-game settings
- Display Mode : Fullscreen
- Resolution : 1920 x 1080 (Monitor : BenQ ZOWIE 240hz XL2540)
- Aspect Ratio : 16:9
- VSYNC : Off
- Triple Buffering : Off
- Reduce Buffering : On
- Render Scale 100%
- Texture Quality : High
- Texture Filtering Quality : Epic - 16x
- Local Fog Detail : Low
- Dynamic Reflections : Off
- Shadow Detail : Low
- Model Detail : Ultra
- Effects Detail : Low
- Lighting Quality : Low
- Antialias Quality : Ultra - SMAA High
- Refraction Quality : Low
- Local Reflections : Off
- Ambient Occlusion : Off
https://linustechtips.com/topic/776392-overwatch-pc-build-need-help/
you might want to upgrade your GPU. I'm not sure if a 1060 can push 250FPS in overwatch.
other than that, it might be worth it to go with a 7700K and a Z series board, so you can OC your CPU to 5Ghz to get higher FPS, since CPU performance does matter a lot in high-FPS scenarios.
BTW: What do you need 250FPS for? nearly no monitors can display that, and the ones that can have adaptive sync anyway
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Im not interested in OC'ing but i need the 250 FPS to make use of 250hz monitor, I think thats how it works at least
Drop CPU cooler
Get B250 mobo
Get 16GB RAM (optional)
Get a better GPU like 1070 and 1080
Get a better PSU, EVGA NEX is mediocre
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
- VSYNC : Off
- Render Scale 100%
A) Will it be able to? No.
  1. 1060 probably will not get you those kinds of frame rates.
  2. that monitor will only display up to 240fps. I do not know of a monitor that can.
  3. If you are going to be going with an Z270 chip set, get a 7700k, or a different motherboard.
B) Yes, though the mix of a locked cpu and an unlocked chip set is not necessarily a wise idea. I also would double check to make sure you won't be running into any clearance issues with the height of that cooler and your chosen case.
C) any surge protector should work. If you are concerned about shut downs during a power outage, look into a ups.
if you have no interest in overclocking, then I would stay away from a Z series motherboard. And that monitor is only 240hz, not 250
This one would be good
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($336.88 @ OutletPC)
CPU Cooler: be quiet! - Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($65.49 @ SuperBiiz)
Motherboard: Gigabyte - GA-Z270P-D3 ATX LGA1151 Motherboard  ($96.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($103.99 @ Newegg)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  ($90.88 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1070 8GB Windforce OC Video Card  ($334.24 @ Amazon)
Case: BitFenix - Nova ATX Mid Tower Case  ($24.99 @ NCIX US)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply  ($47.78 @ SuperBiiz)
Other: Kinguin Windows 10 ($35.00)
Total: $1206.12
Generated by PCPartPicker 2017-05-06 20:59 EDT-0400
GTX 1070
16GB RAM
7700K so you can overclock
although aesthetics are not as good
Laptop:
Much better build for the same price.
CPU: Intel - Core i7-7700 3.6GHz Quad-Core Processor  ($294.89 @ NCIX US)
Motherboard: MSI - B250 PC MATE ATX LGA1151 Motherboard  ($88.99 @ SuperBiiz)
Memory: G.Skill - Flare X 16GB (2 x 8GB) DDR4-2133 Memory  ($98.88 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($88.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($362.78 @ Amazon)
Case: NZXT - S340 (White) ATX Mid Tower Case  ($64.99 @ Amazon)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $1109.30
Add windows from kinguin for $30.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
Total: $1109.30
do you think i should get a cooler or not? btw this is is the build so far im still willing to change it https://pcpartpicker.com/list/hjWJXH
Faster ram is a waste since you can't OC it on b250 and cxm is as good quality but semi modular and cheaper so no reason not to get it. Other than that I have no recommendations, except you might want to get windows from kinguin instead (if it feels too shady for you then you don't have to tho).
The only reason you might want an aftermarket cooler is for acoustic reasons. Up to you if you want it or not. Of course, you could just buy everything and if the stock is too loud for you you could just buy something like a pure rock afterwards.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
thank you for all the reasoning behind the parts, my thought process was alot different and didnt make sense in hindsight, and yes it feels a little too shady for me to get windows 10 from someone other than microsoft, also there are 2 pure rock coolers the pure rock slim and the pure rock, which one should i get? https://pcpartpicker.com/user/2g3k/saved/HtkZLk (the build so far)
Just the pure rock. The slim is for small form factor cases, which isn't applicable to you.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
9 minutes ago, HopTrain said:
https://pcpartpicker.com/user/2g3k/saved/HtkZLk ok here is the last build, sorry if im bothering you lol
Looks great :).
And no worries, I probably spend 1-2 hrs a day on this forum so... It's not really "bothering me" from my perspective xD
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
Just now, DocSwag said:
Looks great :).
i decided to choose a msi gtx 1080 after watching some youtube comparison videos with the graphics card on overwatch, with that is it still compatible with all the other parts? https://pcpartpicker.com/user/2g3k/saved/HtkZLk (updated build again lol)
Yup, looks good. It seems like you're going a bit more premium than originally anticipated xD
You might want to get a g2 psu since you're going more high end. Up to you if you want to spend the extra $40 or so.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
yeah ive never had a good pc before and im tired of lagging and messing around in configs and settings i just want to play the game and ill look into the g2 psu
Guest
