The 780ti is a bit cheaper atm. And its the 4gb 480. Just wondering which is better, i know there are better cards and im not looking for suggestions like "get 8gb" or "500 series is out and same price." Thanks.
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/775932-780ti-vs-rx-480/
I think the 780Ti is a bit better, but the RX 400 series has support for newer technologies, like way better DX12 performance, support for Vulkan, etc.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788000
ive seen videos like this
but im not sure if it shows the whole picture
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788006
780Ti is around a 970, so a 480 is better.
1 minute ago, Colin Donoghue said:
rx 480 because it has a higher clock speed and 1gb more of ram
You can't compare clockspeeds between different architectures. An RX 480 (at 1400mhz~) is equivalent to a GTX1060 (at 2000 mhz~).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788007
yep 500 series if u can find it at the same price as the 480 go for it if not theres only about a 5% perfomance gain between them and u can get most 480s to run at 580 speeds anyways
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788012
I thought the standard 780 was like the 970?
Maybe not in new games.
Laptop:
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788022
580s are cheaper though
My life
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788025
http://www.anandtech.com/bench/product/1441?vs=1595
http://www.anandtech.com/bench/product/1493?vs=1595
With day one drives a 780~970, but after Maxwell drivers get better it pulled ahead.
PSU Tier List | CoC
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788031
780ti gets absolutely demolished in newer titles, especially ones that have a large focus on compute.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788048
Well I have the same gpu core. Handled bf1 on the high preset on 1440 with 60+ frames. Which seems to be what people like. Even had it slightly ubderclokced. And this was before the patches on bf1.
Not sure what your paying but as a 780ti can be had for around 150 and 980's for around 250 I'd go with with the 780 or find a better deal. I'm not much for mid range cards though.
https://linustechtips.com/topic/775932-780ti-vs-rx-480/#findComment-9788065
