Mouse Double Clicking issue
Go to solution Solved by Aytex,
19 hours ago, Donut417 said:
Im kinda leaning toward the Nixeus Revel, as its pretty plain, and I kinda like that, plus it very similar to the Deathadder in terms of buttons. I considered getting another Deathadder but Ive heard that Razer's QC had fallen off quite a bit.
If you're going for the nixeus, go ahead and grab the Dream machines
basically says the dream machines just feels more premium and buttons are more non mushier.
I have a Razer Dethadder. Before you tell me its shit, this guy has been with in since 2011, so I have used this mouse for a while. Anyway now its double clicking at random. Do you guys think the mouse is finally going?
If so what mouse would you recommend? I know that Wireless mice are getting better, like that Logitech one that Luke reviewed a while ago. But, Im not sure what mouse would be good.
https://linustechtips.com/topic/775875-mouse-double-clicking-issue/
It's probably on it's way out. If you don't have any reason you really want a wireless mouse, don't bother with one. They're expensive and they run on batteries that need charging and are bound to run out during the middle of a gaming session.
If you have big hands and palm grip I recommend a Cougar Revenger. Solid sensor, looks pretty good imo and it's pretty comfortable.
I also like the R.A.T series and own a R.A.T Pro S, super lightweight with a good sensor but no RGB (if that's your thing).
Neither are that expensive but are solid mice.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
The company that makes rat went bankrupt
My life
So what? If you buy it at a reputable retailer you'll still have a warranty, unless your country has poor customer satisfaction laws.
It wasn't a popular companty in the first place probaly reallt hard to find stock
My life
Well, I can find it with Prime In-stock on Amazon UK so I'd say it's quite easy to find stock.
16 minutes ago, VinZie said:
Wireless is hell. You can get into battery issues, and it has input lag. I would just get a Zowie FK1. Very comfortable.
Not sure how old its been since you've used a "gaming" wireless mouse but its come a long way up to a point where it competes very well with wired mice.
I've had that issue on my Deathadder chroma which resulted in 3 RMA's and my issue still persists on my refurbished mice.
I would take a look at the Nixeus revel or Dream Machines DM1 Pro S, they hold very good value for the money.
If you want to go wireless i would take a look at the 403.
or whatever grip type you're comfortable with would help.
Here in the US, you dont go thru the retailer for RMA's, you have to deal with the manufacture. So I doubt the warranty would work in that case here.
