mATX or ATX?????
Go to solution Solved by HKZeroFive,
If you're looking for something similar to the Gigabyte Aorus GA-Z270X-Gaming SOC, the closest mATX motherboard in terms of looks would probably be the Gigabyte GA-Z270MX-Gaming 5.
I am going to be building a new pc:
GPU: 1080 ti (FE (I am water cooling))
CPU: i7-7700k
MOBO??? I was thinking: https://www.newegg.com/Product/Product.aspx?Item=N82E16813128995&cm_re=Gigabyte_Z270X_SOC-_-13-128-995-_-Product
CASE: Fractal S for ATX or Fractal S nano mATX
PSU: seasonic 650W titanium
RAM: Gskill 4x8GB (32gb)
STORAGE: 2x 500GB HDD(IDK?) , 1TB SSD (gaming) , 1 250GB SSD(STUFF), 1 256 M.2 SSD (booting/systems)
I really don't need a ATX board, I won't have 2 GPU's ever. Plus I heard that mATX is better for just a single GPU and CPU
I am looking for a good OC mobo with m.2 slots 4x ram slots and under $300
please link me to one thanks :D
I would also like to not that I am water cooling and need at least  a total of 480mm of rad space in my  case
https://linustechtips.com/topic/775584-matx-or-atx/
I don't get it why would be mATX better for single CPU and GPU, than normal ATX.
Too much confusion for my brains right now.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/775584-matx-or-atx/#findComment-9783916
Just now, yathis said:
Drink more vodka, works for me!
It's 7am in the morning xD
Jeasus man ... trying to get me fired? lol
WD My Cloud 4TB
https://linustechtips.com/topic/775584-matx-or-atx/#findComment-9783922
CPU: i7-7700k
https://pcpartpicker.com/product/7VZ2FT/asus-prime-z270-a-atx-lga1151-motherboard-prime-z270-a
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
https://linustechtips.com/topic/775584-matx-or-atx/#findComment-9783926
I am not sure why I said that actually i'm an autist , i heard that mATX had better power distribution and better PCI slots; which is a oblivious given since there is only going to be one 16x slot
https://linustechtips.com/topic/775584-matx-or-atx/#findComment-9783936
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/775584-matx-or-atx/#findComment-9783947
Not sure where you heard that, sounds very off. I don't agree.
If you're building in a full sized tower, mid tower, or anything that fits a full ATX board you should get it.
Smaller formfactors like mATX and mITX are made for their respective sized chassis.
And don't get me wrong, you can put a mITX board in a 900D and it'll look funny as shit:
But going with a smaller board wont really give you a benefit unless you feel like the extra headroom or more plugins for different stuff is useless.
"i heard that mATX had better power distribution and better PCI slots; which is a oblivious given since there is only going to be one 16x slot"
I can assure you, a 16x slot will work JUST as fine on an ATX sized board, and any other that has a 16x.
Smaller wont mean that power distribution improves, in that case all enthusiast would build with mITX boards becuase "it only has ONE PCI-e slot, must be better"
Which doesn't make much sense :)
Either what I just said, or I might be completely wrong. Someone correct me if I am please
https://linustechtips.com/topic/775584-matx-or-atx/#findComment-9783971
smaller  isn't necessarily better. I appreciate the small computer movement. You use it for lan parties or  carry the sucker around.
Mine sits on a desk and it's not going anywhere. A decent z270 atx board will have more just because of the size difference.
Yeah make it small if it suits you. That is a trade off for features you might want or need.
Why you need so small? Isn't that the better question?
https://linustechtips.com/topic/775584-matx-or-atx/#findComment-9784024
