5 minutes ago, killer5247 said:
Guys I was buying extensions for my first build cum mod so which is good quality paracord or nylon reply after thinking
Between the two it's mainly up to aesthetics and choice, paracord tends to have a much tighter weave with a fabric like feel making it very flexible compared to PET or nylon which has a coarser weave.
https://linustechtips.com/topic/775384-cable-material/#findComment-9781546
Which you would be choosing
My personal Build as i am a cool tech enthusiast B|
https://pcpartpicker.com/user/TheSneakyRM/saved/
https://linustechtips.com/topic/775384-cable-material/#findComment-9783998
My favorite is nylon or PET since it tends to be a little stiffer and easier to keep cables in place and I like the thicker weave of the nylon. It really depends on what you fancy.
https://linustechtips.com/topic/775384-cable-material/#findComment-9784050
Is there any huge difference in looks
https://linustechtips.com/topic/775384-cable-material/#findComment-9784054
Mainly what you see there, the paracord on the right has a very small weave and is fabric like, the PET is coarser and depending on the kind you get can be matte or shiny which can look nice with lighting.
https://linustechtips.com/topic/775384-cable-material/#findComment-9784062
