Hey everyone,
I'm new to the forum and have some questions regarding cooling in the Ncase M1. I'm planning my first pc build for this summer and as I have been a console player all my life, I don't know exactly what provides good cooling and quiet operation. From the Ncase homepage I saw the cooler height is limited to 130mm, my question is: Which air cooler should i get?
I plan to overclock a little, but low noise is most important. I have not yet decided on Intel or AMD.
https://linustechtips.com/topic/775311-ncase-m1-cooling/
Yes that case is fine and will get good cooling if you take advantage of the cooling places and put fans were you should.
Pc Specs
CPU: I7 6700k 4.5Ghz  Motherboard: Asus Z170-A Ram: Corsair Vengeance 16GB DDR4  Cpu Cooler: Corsair H100i v2  Storage: Crucial MX300 525GB/Hitachi Deskstar 3TB  Graphics Card: GTX 1080 Founders Edition Case: Corsair 750D Power Supply: EVGA SuperNOVA 850w Keyboard: Corsair k70 Mouse: rival 300
https://linustechtips.com/topic/775311-ncase-m1-cooling/#findComment-9780554
You should be able to fit something like this: http://noctua.at/en/products/cpu-cooler-retail/nh-d9l
Maybe not ideal because you might want to get a top-down cpu cooler becuase the motherboard VRM might like some cooling. But it's an option tho.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/775311-ncase-m1-cooling/#findComment-9780560
Thanks for the suggestion, but since the fans are small wouldn't it be a bit noisy? Again have no prior experience with desktop pc's.
https://linustechtips.com/topic/775311-ncase-m1-cooling/#findComment-9780623
You can't go wrong with noctua fans :P
They are expensive, but they are about as good as it's going to get if you want good case fans and cpu coolers.
Linus even teamed up with them to do a limited run of LTT limited edition noctua fans a while ago.
https://linustechtips.com/topic/775311-ncase-m1-cooling/#findComment-9780677
It's a very quiet fan.
https://linustechtips.com/topic/775311-ncase-m1-cooling/#findComment-9781408
Nice, in regards to fans being expensive, everything is expensive in Denmark, depending on the exchange rate the FE 1080ti cost around $1000...
https://linustechtips.com/topic/775311-ncase-m1-cooling/#findComment-9781894
92mm fans are pretty close to those fans cooling consoles. And they are for random OEM manufacturers. Noctua is top notch cooling brand. If you want quiet operation from case fans too, Noctua is one of better choices. Like there are also other top-down coolers and even small tower coolers which would fit.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/775311-ncase-m1-cooling/#findComment-9784473
