1 minute ago, Suttonspencer said:
I just built my new case with the computer i've been using for quite some time without issue. Now I have it all installed and it wont turn on. What could the issue be? ive plugged all the PSU cables into the motherboard/GPU and I'm not getting any sort of life:(
Photos would be nice to ensure you have the cables plugged in correctly
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/775177-cant-get-power/#findComment-9778857
Just now, Suttonspencer said:
Yeah actually just had to check that haha
I know I've sat there checking wiring before for a good half an hour just to realize that I forgot to flip the switch so I just thought I'd put that out there. Also I would check to make sure your ram is seated correctly as it sometime can cause power issues if not in correctly.
https://linustechtips.com/topic/775177-cant-get-power/#findComment-9778902
5 minutes ago, Suttonspencer said:
  Reveal hidden contents
Ok cool. Check all the connectors are all the way in and try to start to put by shorting out the two power pins for the front panel header
https://linustechtips.com/topic/775177-cant-get-power/#findComment-9778910
3 hours ago, Suttonspencer said:
Probably a dumb question but how do I short the the two power pins?
A screwdriver touching the two pins you plug the "power" front panel connector into. Sorry for the delay. Been at uni for a test
https://linustechtips.com/topic/775177-cant-get-power/#findComment-9779349
On 5/3/2017 at 10:50 PM, MVPernula said:
FIRST PICTURE!
Seems to me like the "splitty" part of the the 24pin to your motherboard isn't fully inserted.
Take it out and remount.
Any idea how to get it fully in? I've tried to shove it in and I haven't had any luck
https://linustechtips.com/topic/775177-cant-get-power/#findComment-9784098
Don't force it. Usually the small cable goes in FIRST, so by the looks of it you have to take the entire cable out of the socket of the motherboard and then plug them in at the same time OR with the smaller one first.
It takes some, and I mean SOME, force to plug the cable in and I know that, but if it's not going in when you'ree really trying something is off.
Slide the small one on the bigger and try again :)
Look at the locking mechanism:
https://linustechtips.com/topic/775177-cant-get-power/#findComment-9784150
