I'm planning to build a new PC sometime in early or mid 2018. I'll be using it for music production, gaming, game modding, photo editing and also programming in Python.
These are my requirements:
ATX Motherboard
Ryzen 5
up to £625 budget.
At least 8-12GB RAM
Thanks in advance :)
https://linustechtips.com/topic/774874-ryzen-build/
Do you have GPU bro ?
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
https://linustechtips.com/topic/774874-ryzen-build/#findComment-9775504
CPU: AMD Ryzen 5 1400 3.2GHz Quad-Core Processor  (£157.97 @ Amazon UK)
Motherboard: Asus PRIME B350-PLUS ATX AM4 Motherboard  (£79.47 @ Amazon UK)
Memory: ADATA XPG Z1 8GB (2 x 4GB) DDR4-2800 Memory  (£50.63 @ Amazon UK)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Aria PC)
Video Card: Sapphire Radeon RX 580 8GB PULSE Video Card  (£225.46 @ Scan.co.uk)
Case: Thermaltake Versa H23  ATX Mid Tower Case  (£26.48 @ Aria PC)
Power Supply: SeaSonic ECO 430W 80+ Bronze Certified ATX Power Supply  (£44.98 @ Ebuyer)
Total: £622.98
Generated by PCPartPicker 2017-05-03 16:39 BST+0100
rip
https://linustechtips.com/topic/774874-ryzen-build/#findComment-9775512
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  (£205.47 @ Scan.co.uk)
Motherboard: MSI B350 TOMAHAWK ATX AM4 Motherboard  (£98.97 @ Amazon UK)
Memory: ADATA 16GB (4 x 4GB) DDR4-3000 Memory  (£92.09 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.98 @ Amazon UK)
Video Card: Sapphire Radeon RX 570 4GB PULSE ITX Video Card  (£162.04 @ CCL Computers)
Case: BitFenix Nova ATX Mid Tower Case  (£26.40 @ Aria PC)
Total: £671.93
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/774874-ryzen-build/#findComment-9775519
Come back when Intel introduces 8th gen of CPU's.
https://linustechtips.com/topic/774874-ryzen-build/#findComment-9775526
1 minute ago, 1kv said:
Yeah.
Memory: GeIL SUPER LUCE 16GB (2 x 8GB) DDR4-3000 Memory  (£164.87 @ Amazon UK)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  (£64.85 @ Amazon UK)
Total: £602.54
Generated by PCPartPicker 2017-05-03 16:41 BST+0100
https://linustechtips.com/topic/774874-ryzen-build/#findComment-9775527
Total: £602.54
Build related: I've heard bad things about post times on the MSI bios (may be worked out) but to be safe I usually say asrock or asus prime (whichever is cheaper).
Non build related I think the best advice for @1kv is to look at current prices, figure out a budget and then save the cash and buy in one go. If you buy a 1600 now and it sits on a shelf for 12 months you will have missed out on Zen2 which will have the same MSRP most likely. Buying this way just means your components will depreciate in value. Its like buying a car piece by piece, by the time you are finished there is a better engine available for the same money.
https://linustechtips.com/topic/774874-ryzen-build/#findComment-9775549
I agree. Thank you all for your ideas, suggestions, and builds.
https://linustechtips.com/topic/774874-ryzen-build/#findComment-9776149
