I currently use an RX 480 Strix with an ultrawide freesync monitor that was overclocked to 80hz. Yesterday, I started playing the Witcher 3 and noticed a lot of stuttering. The fps was still high, but frame times are bad. Here are the things I've tried so far.
- Fresh install of the most recent driver.
- Removed the monitor overclock and brought it back to 75hz.
- Turned Freesync off and had the monitor at 60hz.
- Removed the GPU overclock.
- Used a different monitor.
- Removed the RAM overclock.
- Did a fresh install of the driver from early January.
None of these things worked. I also tried playing GTA 5 and things are even worse than in TW3. Not only there is stuttering, but the frame rates are low, even on medium settings.
Has anyone experienced this? Could my GPU have gone bad?
Lian-li O11-Dynamic | i7-11700K |  MSI Z590 MAG Tomahawk | 64gb Ripjaws 3200MHz | 1tb Nvme SSD + 6tb HDD RAID | Corsair H115i Cooler | EVGA 850BQ PSU | RTX 3080ti TUF | LG C2 65" & Acer Nitro XV340CK Monitor
https://linustechtips.com/topic/774658-rx-480-stuttering-with-freesync/
Use DDU to uninstall your drivers before reinstalling
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
DDU helped. Thanks!
4 hours ago, AMD Spec said:
so whats ur status right now ? totally fixed or still having some choppiness? please provide some detailed info because other users might benefit from your thread
I used DDU and installed a driver from early January that I know works really well with the games I currently play. I also uninstalled all of my games and downloaded them again. Everything is working fine now.
As a side note, DDU came with a lot of viruses when I unzipped the file, so beware.
