I have been experimenting around OC'ing my 7700k for a while, with not a lot of success.
Currently, I have it running at simply 4.5GHz @ 1.19V - I like to keep my system kinda quiet, however would like to at least try to take it further.
In the past, I have tried taking it up to 4.8, I get it at around 1.3V, however I am aware that this is bad, considering most seem to be able to get 5GHz @ 1.3V.
Did I just get an unlucky chip? I though 4.5GHz @ 1.19V was pretty good...
One other problem is the temperatures, I have a Corsair H80i, and at idle my CPU runs at about 35C. Currently, at 4.5GHz @ 1.19V, it reaches about 70C after 15 minutes on full load, is this good?
I have a feeling I got a bad chip here, as when I go 5GHz @ 1.4V, I get a BSOD.
So basically, I was wondering if there was anything I could do to squeeze a little more performance out of my CPU, while keeping temperatures below 80C under load, even if I did end up with a bad chip?
MY SPECS:
Intel Core i7-7700k
Gigabyte GA-Z270 Ultra Gaming Motherboard
16GB (2x8GB) Corsair LPX RAM, OC'd to 3000MHz
Corsair H80i AIO Liquid Cooler
https://linustechtips.com/topic/774571-help-with-ocing-7700k/
Delid.  $50 and you may be capable of 5Ghz at similar temps
https://rockitcool.myshopify.com/
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771425
I have considered this, but I really don't want to take the risk... this was the first PC I ever built, and, as a 15 year old, a 7700k is an expensive CPU, I can't afford to accidentally break it. As I have never done anything like that before, I don't feel confident. If I had an old CPU to practice on I might, but I don't, unfortunately.
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771438
I have a 4790k @ 4.7Ghz full load its pushing 80C, and its been running fine for the past 2 years so no need to worry about that end
It is possible that your chip isn't as good as others, but no need to fret as the gains from those few MHz are not really noticeable
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771440
rokkit will make it safe.  Your CPU is good but the TIM on the die is holding it back.  You can get a 280mm radiator if you want but it won't be as good as a delid
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771442
tbh its very very safe with a delid tool, if you used a vice i can understand but as long as you follow the instructions its easy. all you do is turn a screw and put some thermal paste on a die as well and the ihs.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771463
I know I wouldn't really notice it, but it would just be something to do, I find just messing with PCs is fun, as I am sure many on this forum do too :D
Realistically, would I see performance games in gaming from this, I would happily have a go at overclocking, as it doesn't cost any extra as at the time I got this 7700k it was cheaper than a 7700, but spending money for no noticable performance boost - especially $50, I don't think I could justify. I find fiddling around with PCs fun, as mentioned above, so OC'ing at no extra cost I would happily do.
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771487
you could return the h80i, buy a delid tool and a stock cooler and get better temps :P
Rig Specs:
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771503
Normally yes, however I bought this H80i for £35, second hand from Gumtree. As I am only 15 I need to cheap out on all I can xD
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771507
In games?
Yeah.  A CPU does a certain number of instructions per clock.  To be simple it would be 4.5Ghz * 2 ipc = total of 9 instruction given.  5Ghz * 2 = 10
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771513
ok :P i would offer to delid it for you for just the cost of shipping but my tool broke :(
Rig Specs:
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771520
Yo just saw your profile, can I see the 8 core 1500X?
xDxDxD
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771526
Unfortunately then, delidding doesn't seem like an option.
Adding to this fact, I can't find the Rokkit one in the UK, so it would cost A LOT to get it here.
So are there no other ways, realistically, I could get higher frequencies, if it is as it seems and I got a bad chip?
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771533
Ok, that would be nice, however the fact the Rokkit delid tool doesn't seem to have a UK version, might put that out of my reach anyway :(
Either way, thanks for the help. Both of you.
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771538
Calm down on that, your chip is fine.  It may even be pretty good.  70c is totally normal for a 7700k
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771541
https://www.overclockers.co.uk/der8auer-delid-die-mate-2-hs-003-dr.html
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771547
It's not temperatures I'm worried about, I sorted that out before as my motherboard was feeding way more voltage than it needed, at first, I have dealt with temperatures I would just like to get a little more out of it, if possible.
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771550
Save for a Delid-Die-Mate 2 and some cryonaut grizzly metal TIM.  You will see the biggest change
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771557
6 minutes ago, Syphno said:
Ok as a 7700K user who streams while playing games completely fine while recording and cpu usage peaks at 40% what is the point or benif of OCing
things can go faster without the cpu being at 100% a ferrari is fast at 60% throttle than a focus :P just cos you only use 60% throttle doesnt mean you need to hinder your own performance which intel kindly shafted you for when you bought and unlocked k chip :)
Rig Specs:
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771612
I most likely did not get shafted I'm happy with my purchase, thank you
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771776
happy to be shafted :P if the 7700 none k was unlocked.........
Rig Specs:
https://linustechtips.com/topic/774571-help-with-ocing-7700k/#findComment-9771785
