What is this thing? (help pls)
Go to solution Solved by LogicalDrm,
You don't need it if you are planning on controlling fans from mobo or by controller. Its more for connecting fans to PSU and making them more quiet.
Sorry i'm kinda noob in terms of PC fans...
http://i1363.photobucket.com/albums/r719/Adryan_Wirasyahputra/3pinadapter_zps64791807.jpg
I just bought some Corsair case fans but i don't know what this is for?
is it an extension but why is it so short? and if it's needed, why didn't they permanently attached it with the fan cables?
it will also be greatful if someone post a youtube link of a vid telling me the difference when using fans with or without this "extension" :P
also should i plug my case fans to my mobo or my case fan controller (NZXT phantom 410)?
______________________________________________________________________________________________________________
I also mainly use 7 volts btw and 5 volts when my pc is idle...
When 2 things meet each other, Quantum stuff happens.
https://linustechtips.com/topic/77268-what-is-this-thing-help-pls/
Might be used to lower the voltage on the fans. making them run slower and quieter.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
Pretty sure that's an LNA...
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
It makes the fan quieter, so its a voltage regulator
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
It's a low-voltage adapter. If you are unable to control the fan speed with software or the motherbaord, this is used to slow down the fan, usually to 7 volts.
That bulge in the middle guarantees this, it's a resister.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
