Be quiet fan making weird noise
By
Quackstuff
in Cooling
in Cooling
Solved by vaiwalker,
if it didnt make that before, then yea, probably something's wrong? you could check the RPMs with some software or check in bios, if it seems reasonable enough and temps are alright, shouldn't be a problem. but if it bothers you enough or temps are abnormal, get a new fan
Featured Topics
DreamCat04 ·
Posted in PC Gaming0 -
saltycaramel ·
Posted in Tech News0 -
2
VinSen ·
Posted in New Builds and Planning2 -
1
Fahizzle ·
8
