6 minutes ago, apaar123 said:
Can anyone recommend some really silent pc fans (both 120 and 140mm)which are good looking too.? Led lights are a plus point too
As far as quiet fans go I think most people would recommend Noctua fans
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/772557-pc-fans/#findComment-9749095
Be Quiet Silent Wings 3's.
https://linustechtips.com/topic/772557-pc-fans/#findComment-9749156
Where are you using the fans?
Where are you shopping/located? Budget?
https://linustechtips.com/topic/772557-pc-fans/#findComment-9749191
