i reinstalled windows on my laptop as it was affected by virus. i used windows media creation tool for this. i selected windows 10 pro 64 bit. i selected option of giving product key afterwards it shows activate windows at bottom right. if i dont activate it will anything go wrong? if so pls can any one give me any spare product key you have?
https://linustechtips.com/topic/771716-is-product-key-required/
Use the key you already have, if this doesn't work call the MS service line..
 CHRISTIAN MEMBER
https://linustechtips.com/topic/771716-is-product-key-required/#findComment-9739012
Just go into the setting activate windows and MS should recognize your motherboard and activate it. You only ever need to enter the key the first time.
13 minutes ago, Krishna Dev said:
i dont have any key i used windows media creation tool to download windows 10. it didnt give me ant product key.
You have an OEM or you had a valid/"valid" windows 7 and took advantage of the free upgrade
Either way you likely got a digital entitlement so ya your ok to just click activate windows 10 in the settings.
https://linustechtips.com/topic/771716-is-product-key-required/#findComment-9739024
You have laptop. Unless you have one of those extremely cheap laptops that come without OS from the start (or with linux), your key is imprinted into mobo. When you click to Activate, it will read key from security chip.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/771716-is-product-key-required/#findComment-9739995
