 I am looking for a INTEL gaming pc build. I want to use 2 monitors but want to play games in 1080P on both monitors. The PC should be run the games on 1080P for minimum 3 years. I want to keep the build as cheap as possible. My monitor budget is separate.
I am in CANADA
Please help
Thanks in advance.
https://linustechtips.com/topic/771505-pc-build-help/
3 minutes ago, TheNeonWhiteOne said:
like mirrored or extending the game onto the second? of its mirroring it does need more gpu power than one. if not then rx 480/580/1060 or better
https://pcpartpicker.com/list/dqQMd6
It's a bit expensive, but you didn't have a budget posted, so I just took it at face value. How much are you willing to spend?
"There is a fine line between not listening, and not caring. I'd like to think I walk that line every day of my life."
Desktop:
CPU: Ryzen 5 2600X w/stock cooler, Motherboard: MSI X370 GAMING PLUS, RAM: Corsair Vengeance LPX 24gb DDR4-2600, GPU: EVGA RTX 2070 SUPER XC, Case: NZXT S340, PSU: Corsair RMx 750w, Keyboard: Corsair K50, Mouse: Corsair Ironclaw
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736398
Good looking build, and it's not too expensive. I was expecting it to be $1200 or something.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736405
Nah son, that's ridiculous for a build that's supposed to be cheap. Although tbh I should probably take the shit Toshiba HDD out of the build I suggested, those things are trash.
Desktop:
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736416
You said "It's a bit expensive...." so I was expecting it to be a good amount of $$$. $800 is pretty good for a dual monitor (Basically 2K?) gaming rig.
Mouse: EVGA X17
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736426
Just now, lake12 said:
I want to extend the game to 2nd monitor
So running it like it's one monitor? Like in a surround gaming setup, but with two screens instead of 3+?
Mouse: EVGA X17
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736431
You might want a more RAM but other than that I'm happy with this suggestion.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736432
True.
Also I did a Ryzen variant of the same build in case he wants to do streaming/video editing shit: https://pcpartpicker.com/list/rLKxQV
Desktop:
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736433
I got the bare minimum, seeing as he wanted it to be cheap. But if he wants to get 16gb, he can edit the build to his liking.
Desktop:
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736437
Also, as a owner of that case, I will say it's most adequate even if it seems exceptionally cheap.
This only downside I had was that you can't top mount a 240mm RAD and the dust filter is easily removed and cleaned.
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736456
Correction: You can top mount a 240mm RAD but it'll be outside the case.
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736470
Just get an ultra wide
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736472
An ultrawide monitor would prove to be of better benefit, if you're tight on budget you can make a rx580 + 29UM68-P, I own two of these screens and I can assure you they are awesome, beautiful image quality, IPS, you can have 75hz with FreeSync using the rx580... 2560x1080p sweet spot is 29inch, the pixel density is amazing.
Ultrawides are the best thing when comes down to gaming in my opinion and nowadays with the support getting bigger and bigger I can't see why not take your chances with the 21:9 ratio.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736508
Though I would get at least a 144hz for that res but 100hz is the lowest I would ever go
Quote
PCPartPicker URL
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736541
This is VERY similar to the build I just did and I think it would do the job nicely. I went with a WD Blue for my HDD and Crucial MX300 for the SSD, and with a slightly higher budget got an AsRock H270 Pro4 mobo, Corsair 270R case, Corsair Vengeance Ram, but got a lesser PSU which is a EVGA 600B.
Those are really all just slight variances in the build you suggested, which I think will fit OP's needs nicely if he sticks with your suggestion.
CPU: Intel Core i7 8700k 3.7Ghz MOBO: AsRock Z370 Extreme4
RAM: Corsair Vengeance (4x4) Storage: Crucial MX300 275Gb | WD Blue 1Tb
GPU: XFX RS RX480 8Gb Case: Corsair 270R PSU: Seasonic Focus+ 750w
Monitors: HP 22cwa | BenQ BL2420PT  Cans: ATH-M50x
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736549
5 minutes ago, Zic05 said:
Honestly refresh rates are a subjective thing, the bottom line is simply try getting anything above 60hz, how above depends on how much you actually need or care for, CS:GO hardcore players will definitely need more hz, meanwhile those who rather play slower paced games, single player campaign and what not 75hz already is a very sweet spot.
Personally from what I have seen the 29inch 2560x1080p panels really are limited to the 75~90hz line, the 144hz ones are only if you go 34 inch but then there is pixelating since the pixel density(2560x1080p) isn't ideal any more... the best possible would go to the 1440p ultrawide that are all 34inch 100hz At least... but that would be way off OP's budget.
Personal Desktop":
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736566
Thanks! :)
Desktop:
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736700
Gaming on two monitors is not going to work, at all. Either get 3 or an ultrawide.
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  ($287.50 @ Vuugo)
Motherboard: Gigabyte GA-AB350-GAMING 3 ATX AM4 Motherboard  ($147.99 @ PC Canada)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($154.98 @ DirectCanada)
Storage: Western Digital Green 120GB 2.5" Solid State Drive  ($61.75 @ shopRBC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($58.83 @ Vuugo)
Video Card: Sapphire Radeon RX 480 4GB NITRO D5 OC Video Card  ($266.00 @ Vuugo)
Case: Thermaltake Urban S21 ATX Mid Tower Case  ($39.99 @ Memory Express)
Power Supply: Corsair CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.99 @ Memory Express)
Monitor: LG 25UM58-P 25.0" 2560x1080 75Hz Monitor  ($214.99 @ Memory Express)
Total: $1322.02
Get an R5 1400 if you want to save some money. XFire support so you can add a 2nd RX 480/580 at any point if you want.
Alternative RAM choices;
https://ca.pcpartpicker.com/product/3CdFf7/gskill-ripjaws-v-series-16gb-2-x-8gb-ddr4-3000-memory-f4-3000c15d-16gvkb
https://ca.pcpartpicker.com/product/7PFXsY/corsair-vengeance-led-16gb-2-x-8gb-ddr4-3000-memory-cmu16gx4m2c3000c15
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/771505-pc-build-help/#findComment-9736860
