I need someone who knows how to use gamemaker 1.4 "fluently."
You can find where I took the code from from HearBeast's random level generator playlist.
Some important information:
Sprites: spr_player, spri_enemy - self explanatory
Backgrounds: bg_floor, bg_wall, bg_walltiles - self explanatory
Scripts: move (movement for the player), grid_place_meeting, get_path_to_player (collisions; here is the video that I took this from -
Objects: Level(randomly generates the level), Player(the actual entity the moves around), Enemy(enemy = enemy)
Rooms: rm_one - self explanatory
Macros: stated in the first part of the playlist above.
Problem: I need the enemies to pathfind to me but then there's a catch, I need it so they can't just find you all the way across the map, I need a radius in which they can detect me and they cannot detect me behind the walls, other solid objects.
I need to code for this ^
I'm also a begginner and is using gamemaker for a school project so please explain "carefully" otherwise I would not understand. Ask me anything that you might/will need to help me. Thank you in advance.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/771415-gamemaker-14-help/
5 minutes ago, Jasun said:
Snip
Because gm 1 isn't available and I never learned the typed version of gml I can't say for sure.
I briefly read your problem and it seems you want enemies to chase you but only if you're close to them.
In the enemy class/object script add an integer number variable called detection radius. Give it a value (i.e. 10... or 100 depending on how big units are in gml)
next in one of the steps (begin middle or end idc) see if you can run a distance command.
I.e. :
distance (this enemy, to player)
if distance is less or equal to detection radius
then
chase player
else
no else statement.
https://linustechtips.com/topic/771415-gamemaker-14-help/#findComment-9735667
