looking to do a Liquid cooled pc new to it have a list of parts and layout
ok i found a problem with my pump / reservoir layout. The 3 hole cap that i was planing to install onto the reservoir is make for a different size tube as a replacement it was not well described on new newegg or Alphacools web site tho i have a solution that will work as a replacement. i looked at a pump/reservoir combo from thermaltake. I got 1 that will fit between my hard drive cages and my gpu as it sticks out past the mobo.
I am unsure if i will have room for one with a better flow output but i like to have a stronger flow in my loop. does any one know what the tube dimensions of the Reservoirs from thermaltake
all of these have a top inlet and a fill port that i am looking for
the 3 in mind i have are the flowing
74.5 (L) x 62 (W) x 352.8 (H)
247 (L) x 81 (W) x 65.9 (H)
This is the one i prefer but the 87.4 with is a concern i would like to know if the reservoir will fit between my gpu and hard drive bays with a space of 70mm ish (+-5 mm)
94.1 (L) x 87.4 (W) x 309.7 (H)
