Hey guys,
I have a rig I've been using for about 5 years now an I think it's time to do abit of upgrading, currently I have
Motherboard z77-ds3h
CPU intel i5 3750K 3.4ghz
CPU cooler zalman cnps10x
Ram corsair 8gb 4x2 1600mhz
Gpu msi r7770
Ssd corsair force 120gb
Psu tagen 480w
Case zalman z11 plus
and think of the following to upgrade too
Just won't to get over opinions if this is a good idea or to change anything, going to a computer fair in a few weeks so hopefully pick these up cheaper there if not order online
thank you
https://linustechtips.com/topic/771195-upgrade-advice/
I find that PSU to be ALOT more than I find but if it floats your boat. and I dont think you will get any bottle necks
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/771195-upgrade-advice/#findComment-9732703
RX 480 or 580, 550W PSU and SL308.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/771195-upgrade-advice/#findComment-9732712
For the PSU, I recommend https://www.alza.co.uk/seasonic-m12ii-520-bronze-d167083.htm?kampan=pcpartpicker_uk_prodej_atx-2-2-power-supply_ue313h2&utm_source=pcpartpicker_uk&utm_medium=product&utm_campaign=pcpartpicker_uk _prodej_atx-2-2-power-supply_ue313h2&IDP=7291
For RAM, since DRAM prices are pretty high right now with no end in sight, why not buy used? You can buy DDR3 pretty cheap from CEX, and as long as you don't mind having RAM that might not match with your current stuff this is a good idea. I can pretty much safely say it'd be very hard to find RAM cheaper than this. Plus you get a two year warranty from CEX themselves, and most RAM has lifetime warranties anyway.
https://uk.webuy.com/product.php?sku=SMEM9QAI#.WP6MRcnTWUk
Get a 570 if you can, unless you find a 470/480 reduced.
As for the SSD, the only differnce you'd notice is that you got a bigger SSD. The speed difference between different SATA SSDs is neglegible. So it's fine getting an SSD that's not a Samsung for cheaper.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/771195-upgrade-advice/#findComment-9732731
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/771195-upgrade-advice/#findComment-9732750
6 minutes ago, JDE said:
Personally I would recommend the CX550M over the M12II.
The M12II is a couple £ cheaper and uses nicer components. It's also got a 5 year warranty, that's longer than the CX500M's 3 years.
https://linustechtips.com/topic/771195-upgrade-advice/#findComment-9732790
