Applying Vinyl wrap
Go to solution Solved by ARikozuM,
I would recommend something more rounded than a credit card, but it will suffice.
X-Acto/scalpel would be fine.
Isopropyl alcohol to clean the surface of oils would be better than leaving grime on the surface.
Hair dryer is perfect and I would recommend having someone else hold the dryer while you manipulate the material.
Also, I'm surprised no one answered your question when it is painfully easy to answer.
Hello! I want to wrap my keyboards with a carbon fiber vinyl wrap but I want to make sure I have all of the tools I need before I attempt it. In place of a squeegee, can I use a credit card? instead of a razor meant for vinyl, can an X-Acto knife? Do I need an application fluid for this project? If I do how much would I need? Can I just get a small bottle for this project? Also is a hair dryer a good substitute for a heat gun? Thanks!
https://linustechtips.com/topic/771179-applying-vinyl-wrap/
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/771179-applying-vinyl-wrap/#findComment-9732567
alright thanks. I thought that I could use all of that stuff, but I just wanted to make sure.
https://linustechtips.com/topic/771179-applying-vinyl-wrap/#findComment-9732570
No need for applicator or adhesion promoters, if you can the best is to not use heat as it doesn't add stress into the wrap as that is what cause it to peel or pull up, however sometimes it's not possible to wrap it wouldn't any heat.
-Moved to Modding Section-
https://linustechtips.com/topic/771179-applying-vinyl-wrap/#findComment-9732610
