2 minutes ago, crasch48 said:
why hasn't someone(you guys maybe?_ develop an integrated cooling fin pielter cooling to enhance cpu/gpu cooling?
TEC (thermal electric cooling) is a highly inefficient way of cooling. The reason for this is that it (ultimately) adds overall heat into the system. then the added advantage of any cooling done by the peltier also needs to be able to cool the CPU down enough that the CPU's heat doesn't overheat the peltier, causing it to heat up everything even further and not really do any cooling (there is a thermal limit to how much heat a peltier can handle before it stops functioning properly). Lastly there is the caution of any "lower than ambient" cooling solution. Once you bring your temperatures below ambient temps, you run the risk of condensation... and if you have not taken the necessary countermeasures to combat this, condensation will fry an entire system.
So its not that no one ever does this. Some enthusiasts do TEC for fun and its actually pretty decent when you know what you're doing.... but there are SO many reasons why its not advisable for the general consumer and with how risky it is, I doubt any company would ever offer it as a commercial product.
I did this to a 40W quad-core CPU with a 100W peltier plate. It worked well enough but the temperatures were nothing to be impressed about. Trying to cool a 65W CPU resulted in thermal run-away. The way it works it isn't functional for such a task. Now a refrigerator compressor on the other hand would work wonders
Just now, crasch48 said:
thanks for the intelligent reply!!
Don't let any of that deter you from trying it out if that is what you wanted... That is the territory of the enthusiast after all! we wouldn't be called enthusiasts if all we ever did was the practical things ;)
-Merged multiple topics of the same name-
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
