Headphone jack not working on motherboard
Drkrinklez
I have the Gigabyte  B85M-DS3H-A Motherboard and I have everything connected properly. The headphone jack doesnt work on my case and nor do the ones on the motherboard. Is there any way to fix it?
Is your volume muted?
seems strange that both jacks don't work. so it seems like a software issue.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
Ive updated my drivers
3 minutes ago, nerdslayer1 said:
revert back
it never worked in the first place...
hardware issue
If you've already tinkered with all the settings and still can't get it to work, it could be hardware. Try something like https://www.amazon.ca/AUKEY-Aluminum-Headphone-Microphone-Computers/dp/B01MU5SIGD/ref=sr_1_1?ie=UTF8&qid=1492966129&sr=8-1&keywords=aukey+usb+sound+card
I have one for my laptop at work, where the sound card was noisy (static). Plug this in, and speakers into it, and problem solved!
