So I have an Amd FX-6300 that has a missing pin right were the red square is on the image (My camera sucks so I just grabbed an image off Google) and I can't find a proper pinout of an AM3+. I want to get an Am3b (Am3+ and Am3 compatible?) motherboard for it but first I want to know if it will work? From what I can see its either a ground, no connection or power connection.
https://linustechtips.com/topic/769837-am3-missing-pin/
what is this pin porn? check with google if your motherboard supports your CPU. There is a good chance it does.
Also I can see at least one other pin on AM3 less than AM3+. You stressin bout nothin
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/769837-am3-missing-pin/#findComment-9718526
Look at pages 7 and 8
http://wfcache.advantech.com/www/certified-peripherals/documents/96mpaa-2.8g-2mam3t_Datasheet.pdf
Also get something like 24G Kanthal and drop it in where its supposed to go.
Or get a sacrificial CPU
Breaking things 1 day at a time
https://linustechtips.com/topic/769837-am3-missing-pin/#findComment-9718660
Just now, Trentius_ said:
@TubsAlwaysWins That is the am3 socket datasheet not the am3+/am3b. "24G Kanthal" what is that?
Oh sorry didn't realize that was AM3 not AM3+.
24G is the gauge and kanthal is a small type of wire. I have some from vape stuff, but you can use it in replacement of a CPU pin
https://linustechtips.com/topic/769837-am3-missing-pin/#findComment-9718689
@TubsAlwaysWins Alright I just googled 24G Kanthal and got really confused thanks for the tip that will probably be useful in the future, also I do have an older am2 Cpu that I delidded only to crush the die later on that I have been using to practice replacing pins.
https://linustechtips.com/topic/769837-am3-missing-pin/#findComment-9718703
Here give me a sec. Making a vid for you
Uuuuuuggggg my internet is slow.
https://linustechtips.com/topic/769837-am3-missing-pin/#findComment-9718705
Just now, RGProductions said:
It's just dumb to start vaping unless you use it for it's intended purpose: Get people off cigarettes.
Well I have my reasons. They may seem stupid to most but they work for me.
Also this is getting a bit off topic. If you wanna talk message me
https://linustechtips.com/topic/769837-am3-missing-pin/#findComment-9739068
Yeah, let's stop. I just have that one guy near me that thinks he's "vape Jesus"
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/769837-am3-missing-pin/#findComment-9739070
