Might work?
Go to solution Solved by miyabwah,
Yes. Not for CrossFire, though .
Im getting an R9 290 at the end of the month and I am wondering if my power supply is enough to handle it along with a FX 8320?
I ask this because the R9 290 is quite power hungry and not sure how much stress it will put on my power supply.
PSU: Antec 620w continuous output (80 plus)
Da Rig : Mobo: Asus M5A97-r2.0 | Cpu: FX-8320 (4.1ghz) Stock cooler | Gpu: Sapphire R9 290 | RAM: 16GB Patriot Intel Extreme (1600mhz...for now >:]) | PSU: Antec 620w continuous | SSD: Corsair Force 60gb (boot) | HDD: WD 500GB 7200rpm  WD Blue 1TB | OS: WIndows 7 Ultimate 64-bit |
https://linustechtips.com/topic/76974-might-work/
jup enough! :)
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/76974-might-work/#findComment-1055899
Thank you all for the responses.
https://linustechtips.com/topic/76974-might-work/#findComment-1055935
