Recently I have bought a few more fans for my Desktop, at this current moment of time I have seven fans and have been looking for a Fan Controller.
As of right now, my fans are connected by a single 'one' to 'five' splitter running at 100% however I would like to be able to control the 'noise' levels.
I have the Thermaltake Core X71 case, can anyone recommend any good 'Fan Controller'?
https://linustechtips.com/topic/769571-fan-controller/
Just curious, why do you need so many fans?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/769571-fan-controller/#findComment-9714829
if you weren't worried about controlling each fan individually, there is plenty of software out there that would control them for you, if you're using an asus motherboard, some come with software within AI Suite. other options include 'SpeedFan'
Current Specs:
Intel Core i7 6700k
RTX 3060ti
32gb Corsair Dominator Platinum 3000MHz DDR4
Asus Z170 Pro Gaming ATX
Corsair RM850x PSU
Corsair H55
1TB Seagate SSHD
4TB Seagate Barracuda
500GB Hitachi HDD
256GB Samsung 960 Evo M.2
BeQuiet Silent Base 800
Corsair M65 Pro RGB
Corsair K70 Lux RGB
Roccat Taito
Xbone Controller
Logitec Z333
Samsung SyncMaster SA10
LG Ultrawide 25"
https://linustechtips.com/topic/769571-fan-controller/#findComment-9714835
Well to be honest, I am a man about Aesthetics. :)
The Thermaltake core X71 is a large case, and I would like it to be 'full' sort to speak, with me having an AM3+ CPU more cooling the better.
I have tried SpeedFan with my 'one' to 'five' cable, but it does not work at all.
https://linustechtips.com/topic/769571-fan-controller/#findComment-9714839
Try the NZXT Sentry Mix 2
"There is a fine line between not listening, and not caring. I'd like to think I walk that line every day of my life."
Desktop:
CPU: Ryzen 5 2600X w/stock cooler, Motherboard: MSI X370 GAMING PLUS, RAM: Corsair Vengeance LPX 24gb DDR4-2600, GPU: EVGA RTX 2070 SUPER XC, Case: NZXT S340, PSU: Corsair RMx 750w, Keyboard: Corsair K50, Mouse: Corsair Ironclaw
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/769571-fan-controller/#findComment-9714874
Just now, GrantW said:
Simple and basic... Not too bright. Which is good.
Any others though? Want to consider other options.
I have found an Akasa Six Fan Controller which looks good.
Thermaltake Commander FT perhaps?
Desktop:
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/769571-fan-controller/#findComment-9714916
Had a look at that, although it would look 'fancy' sort to speak, I believe it would be too 'fancy' for the front, if that makes sense?
I am stuck between the NZXT Sentry Mix 2 or the Akaska Six Fan Controller...
https://linustechtips.com/topic/769571-fan-controller/#findComment-9715011
Yeah, I get what you mean. It's pretty bright and has a lot of different colors, seeing as it's touchscreen.
And I'd recommend the Sentry Mix 2. It's a great fan controller.
Desktop:
Laptop:
Lenovo IdeaPad S540
https://linustechtips.com/topic/769571-fan-controller/#findComment-9715050
What fans are you trying to control and what header are you currently powering them off of?
https://linustechtips.com/topic/769571-fan-controller/#findComment-9718554
