Thanks @Enderman for sharing our PDF! Best of luck @jubjub on your case build.
Since this PDF was originally put out (it is on the older side, although all of the info is still accurate), we've also added ATX and mini-ITX enclosure templates to Protocase Designer, which you may find helpful. Once you've downloaded the software, you can select your case template and customize it however you want.
Happy designing!
Happy designing!
I completely forgot about protocase, what's the pricing like? I might just get what I want from you guys
Pricing is hard to say without having the design completed, since everything we do is custom. But that is a nice feature about Protocase Designer - the real-time quoting means you can design your case, and as you go, get a price quote anytime you'd like.
Check it out, and let me know if you have any questions. (Our wiki has a lot of great info too).
