I have a PG258Q and it supports 3D Vision. I've always been interested in giving it a try but I've never had a monitor that was capable of it. Anyone out there with a 3D Vision kit that can provide some input would be much appreciated.
I've seen 3D in movie theaters and in BestBuy but I've never tried 3D Vision.
https://linustechtips.com/topic/768560-is-3d-vision-worth-it/
1 minute ago, yathis said:
Yes its worth it bro
Any issues? I know some games have iffy support for it.
https://linustechtips.com/topic/768560-is-3d-vision-worth-it/#findComment-9703152
3D with gaming aint worth it.. I had it with nvidia 3D vision and AMD on my 3D Projektor.
Iffy support is underwhelmed ..
The best 3D game imho was Overlord it has amazing depth.
All games with somehow native 3D support look fine but the rest is like watching a 2D movie converted to 3D
CPU
Intel  i9 13900k
Motherboard
Asrock Z790 Taichi
RAM
Kingston Fury Beast DDR5 RGB 32GB 6000MHZ
GPU
MSI GeForce RTX 4090 GAMING TRIO 24G
Storage
Samsung SSD 980 PRO 1TB
Unraid NAS 10Gbit about 50TB HDD's, i713700k 64GB DDR5 crucial @ 5800Mhz
Win11 Workstation
https://linustechtips.com/topic/768560-is-3d-vision-worth-it/#findComment-9703195
How will it worth if you use nvidia 3d vision with amd which is not compatible to each other?
https://linustechtips.com/topic/768560-is-3d-vision-worth-it/#findComment-9709349
actually with TriDef you can :D but till November 2016 i owned a GeForce 770gtx after that i own a fury atm, my Projektor is still 3D so i tryed both :D
CPU
Intel  i9 13900k
Motherboard
Asrock Z790 Taichi
RAM
GPU
Storage
Win11 Workstation
https://linustechtips.com/topic/768560-is-3d-vision-worth-it/#findComment-9709566
3d gaming died ages ago! same way movies are heading that way.. very few new games actually suport it natively... i dont even think its woth the $5 glasses...
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/768560-is-3d-vision-worth-it/#findComment-9711492
