Posted April 19, 2017 Is the G602 good for FPS games like CSGO? Just wondering, because I use my G602 for CSGO Link to comment https://linustechtips.com/topic/768466-g602-for-fps/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 19, 2017 If you think the shell fits and you're doing good ingame then its clearly good for you. FPS <3 Flick G1 Review Nixeus Revel Review Link to comment https://linustechtips.com/topic/768466-g602-for-fps/#findComment-9701959 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 19, 2017 If you dont have problems then its fine, no need to spend money on non issues Link to comment https://linustechtips.com/topic/768466-g602-for-fps/#findComment-9701967 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 19, 2017 Modern gaming mice from reputable brands are all good enough that your personal performance is going to be a much larger factor than the slight differences between mouse sensors and wireless v. wired. if you have to insist you think for yourself, i'm not going to believe you. Link to comment https://linustechtips.com/topic/768466-g602-for-fps/#findComment-9702036 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 19, 2017 Better players use lower sensitivities. If you're playing at high sensitivities, you're not playing to your full potential. If you're playing at low sensitivities, the G602 isn't ideal due to its 152g weight. Link to comment https://linustechtips.com/topic/768466-g602-for-fps/#findComment-9702075 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 19, 2017 Author 27 minutes ago, Nimrodor said: Better players use lower sensitivities. If you're playing at high sensitivities, you're not playing to your full potential. If you're playing at low sensitivities, the G602 isn't ideal due to its 152g weight. I think I need a bigger mousepad now, I use the SteelSeries QCK Link to comment https://linustechtips.com/topic/768466-g602-for-fps/#findComment-9702216 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 20, 2017 G900 ftw CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/ GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers Link to comment https://linustechtips.com/topic/768466-g602-for-fps/#findComment-9709443 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
