 First PC
Hello,
I am an amateur who just got into gaming for a year and a half.
This is my first build so I am nervous as hell about it. Apologize if I made any noobie mistake since this is an exciting and new experience for me.It would be of great and a lot of help if you guys can take a moment to evaluate it and make any recommendations for me.
 Parts list(All of the parts list rates here are in Rs)
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor
Motherboard: Gigabyte GA-B250M-D3H Micro ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive
Video Card: MSI Radeon RX 480 8GB ARMOR 8G OC Video Card
Case: Thermaltake Versa H21 ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Certified ATX Power Supply
Some of the pricing of parts  is weird here in India.The RX 480 costs less than a RX 470.
My worry is regarding the cpu since it is a dual core
I largely play like the far cry series,assassins creed,just cause ,etc therefore would the pc handle them well?
These are my doubts and just another thing I really like the community  here? . Guys please continue the good work.
https://linustechtips.com/topic/768140-my-first-pc/
6 minutes ago, NKg said:
 First PC
Hello,
What's your budget?
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9697756
G4560 is the weakest part here. If Ryzen is available then 1500x and b350 motherboard from known manufacturer. If not then a i5 7400 or 6400.
Desktop benching:
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9697790
Seems fine.
However, PSU could be better. Also, go for a better CPU IF you can afford.
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9697799
Will there be any upgradability issues with amd since I want to upgrade my cpu down the line? Since the LGA 1151 socket gives me option to upgrade to kaby or sky lake .
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9698666
G4560 is a HT dual core and was considered one the best budget cpu's. Also G4560 is a Kaby Lake cpu lol, I assume you meant an i5?
@deXxterlab97 am I wrong about the Pentium G4560?
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9698692
27 minutes ago, NKg said:
That was the decision I was split on regarding the g4560.Thought the hyperthreading could do the job but apparently it doesn't
That is the opposite of what I said lmfao?
The G4560 is budget, and is better than an i3, but not better than an i5. If you want to go I5 on a budget, get it locked (or splurge for an i7 locked).
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9698879
Your right.I probably should go for i5.The cpu was my main concern.Have to make some changes in the choice.Anyways thanks a lot.☺
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9698945
Switch the samsung evo to a cheaper ssd (Adata 128gb), you don't need m.2/pci-e for a gaming rig, it literally makes no difference for the cost.
Should give you room for a $300 CPU from a $60 CPU
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9698966
5 hours ago, NKg said:
 First PC
Hello,
Try get a ryzen 5 1400 or a 1500X id recommend the 1500X for an extra 8Mb of L3 Cache. Plus B350 mobos are cheap enough
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9699026
AMD's upgrade cycle was slow, but looking at how fast it released the RX 500 series after the 400s even though they are 90% identical, the new FM4 socket should be used for the next 3-5 years, giving options for upgrade
Desktop benching:
https://linustechtips.com/topic/768140-my-first-pc/#findComment-9700867
