I am new to building and am looking for suggestions on airflow/fan configurations. The mastercase pro 5 comes with 2 fans in front and 1 in back as stock (both 140mm). Will that be enough? Do I need to add 2 fans on top for additional exhaust? Any suggestions are welcome.
Here is my potential build:
CPU: *Intel Core i5-7600K 3.8GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: *Gigabyte GA-Z270XP-SLI ATX LGA1151 Motherboard
Memory: *Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory
Storage: Western Digital Blue 500GB 2.5" Solid State Drive
Storage: Toshiba 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/767902-fan-configairflow-suggestions/
17 hours ago, xhantus404 said:
You can sure go for more, but the thing with case fans is that you quickly hit diminishing returns. I'd say keep it as they are, 2 intakes in the front, one exhaust at the back. If you are unhappy with hardware temperatures and upon opening the side panel the air inside feels very warm, add a third intake to the front - I know for sure it can support up to three 120mm, not sure it can also support 3x140. If that doesn't help, add fans to the top. But I think you will be fine right away :)
I think all sections can handle a 120 or 140mm.  I will have an optical drive in front which I think will block a section (it can fit 3 fans total) in the front from putting a fan so it will allow only 2 intake.
19 hours ago, mrkilla22 said:
If I was to upgrade after I felt it was running too hot, would I just want to add 1 exhaust fan to the top?  I think that would make a neutral airflow, correct (2 intake and 2 exhaust)?
That or add more intake. Depending on which part is hot. But I highly doubt you have issues. I've been running 3 fan config for past 6 years and haven't had any issues with temps. Granted, it was 1x200mm in, 120mm rear and 140mm top out first, then 2x140mm top out before current 2 140mm in, 1 140mm out.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
