I just helped my friend build a computer and we opted for a 480 over a 1060/1070 because of budget and Freesync support (that extra budget quickly went to a monitor that he didn't need).
He has the exact same GPU as me, an XFX RX 480 GTR 1288MHz. My card usually maxes out around 60-65*C in my case with it hitting 70-75 in some games if I turn up certain settings. His card is hitting 85*C in the same games and I know from experience that the fan noise at that temp is going to be outrageous. I'm not worried about the card getting damaged since it is still technically inside the safe threshold but it confuses me how his runs so much hotter.
He is using a very budget oriented case ($35 USD) and per my advice has moved the front fan from blowing air into the basement to blowing air towards the GPU. This help a little bit (will need more testing to see how much of a difference) and he is opting to leave the side panel off for better thermals. The only other thing I can think of is that his monitor being a 144Hz is keeping the GPU pegged at 100% load at all times.
TL;DR Does a 144Hz Freesync monitor make a GPU run hotter because the GPU would be at 100% load more often?
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/767876-480-overheating-on-144hzfreesync/
With the XFX GTR, no need to worry. It can handle being run at 100% for hours without overheating.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
I'd say it might just be bad thermal paste.
From my experience , replacing the stock thermal paste on a gpu can go a long way ( lost 10°C on my 290x when i replaced the stock TIM )
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
He's not going to go for a TIM change. He lives on the west coast and I'm on the east. Helping him build his system over skype took 12 hours to complete. No, that's not an exaggeration. He's so scared of breaking a part of his build that he babies it to unnecessary levels. Pulling the cooler off of one of the most expensive parts in his system is something he's not going to be comfortable doing.
@Spoderman!! @Coaxialgamer
The monitor doesn't matter, but spitting out a lot of frames will make a GPU got (this will happen regardless of your monitor). The way around this is to cap your fps. The Long term fix is to get a better case.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
8 minutes ago, YongKang said:
What case is your friend using?
This piece of crap.
1 minute ago, DragonTamer1 said:
The only thing I would suggest is adding another fan in the front for more airflow. The RX480 XTR has one of the best aftermarket cooler. Other than that, I would suggest capping the framerate for not working the GPU too hard.
